Ignored. This is beyond salvageable
Thanks.
16 cores might be fine, but if you are stuck at 16 cores that means that your 300 euro r5 is also stuck at 6 cores, which is definitely not fine.looks like AMD has realised there's not much point to go above 16 cores on the mainstream side so zen 5 will also just top off at that.
I feel like even 16 cores is probably a bit unnecessary, and if you really need the cores just go to threadripper which should start at 16 cores anyway.
its 2023 now, 6 cores should be the minimum, 8 the standard and 12 is ideal for all round use. as the recent X3D chips have proven, IPC gains and cache is more important than core count.
You talking about the 13600k? That does over 24k at stock. It's faster than a 12700k. You talking about something else?
According to tpup, the 7700 gets 18.5k. So it's both slower and 50% more expensive than the 13500. What the heck are we talking about here?13500, 21,216: £240.
7700, 20,400: £330.
I've bought a Ryzen 7600 and it pretty much maxes out my 144Hz monitor at 1440p for gaming, no real need for more now. I can upgrade once the prices drop and I need more umph.if the performance of just 6 cores goes up by double digit % with each generation that is definitely still fine, especially for gaming.
As we've seen with some of the older 16 core chips like the 3950x, they are almost dead products at this point as the latest 7800X3D spanks it at gaming, and is almost quite similar at a lot productivity apps as well
You said 7700, I thought you actually meant the non x. The x gets 19800,still slower and vastly more expensive.7700X
AMD Ryzen 7 7700X - Benchmarks, Specifications, User Reviews & CPU Comparisons
Benchmarks, specifications, and user reviews for AMD Ryzen 7 7700X. Compare the CPU with other processors and find out how it performs in tests.www.cpu-monkey.com
Will you stop posting with so much anger? Everytime you apply your fingers to the Keyboard the thread goes to ####..... We are trying to have a grown-up conversation here. leave or calm down.
What anger are you talking, I'm completely zen, just mentioning facts. The fastest 8 core zen 4 is both slower and more expensive than the slowest intel 14 core. Okay
Interestingly the 7600 performs a little better than my 5800X3d so there's obviously a number of factors, IPC, frequency and cache. I reckon this will be good until the "8800X3D" has dropped in price. It really depends on when you decide you need to upgrade.Getting a six core now mean you will need to upgrade much sooner, which is good for AMD sales. The base CPU should be 8+ cores buy now. Hopefully the consoles will get a core bump, if/when this happen, the six core will be in real trouble.
It not about how the 7600 performs or IPC, it’s about what developers target. If 90% of the user base has 4-8 cores, developers will target 4-8 cores. This will only change when the base core count increases. If the base core count was 8-16, games could have much better physics and destructible environments which can improve gameplay much more than extra graphics.Interestingly the 7600 performs a little better than my 5800X3d so there's obviously a number of factors, IPC, frequency and cache. I reckon this will be good until the "8800X3D" has dropped in price. It really depends on when you decide you need to upgrade.
There's your issue, Nvidia partsNope, 6 cores is not enough for gaming. I used a R5 7600 with a 4090, Cyberpunk was unplayable with huge FPS drops, CPU cores pegged at 100% the whole time. It and many other games, need 8 cores, especially when you turn on ray tracing (it has a CPU overhead as well as GPU overhead).
Really? You tried cyberpunk with RT on a 6950xt and it played well? I mean come on...There's your issue, Nvidia partsSeems good so far on a 6950XT with the 7600 and SAM.
It requires processing power. More cores of the same architecture and frequency provide more parallel compute. If the algorithm can use parallel compute, extra cores help. If you don’t have the cores, nobody will work on the algorithms to use them. Even if the frequency is dropped down, parallel compute can give big improvements at less power/heat.No they won't. Destructible environments and physics don't in any way depend on core count.
