- 31 Oct 2005
- Wirral
Hi Firestar_3x,You get things like wifi control, the filtering is better, the included remote is far better, indoor units look much nicer, extras like 3D auto which cools the room dynamically over time.
It's one of those things, if you're going to the expense to fit this might as well buy the better stuff to start with.
I'd seriously consider a multi-split system, multiple outdoor units are an eyesore.
Mitsubishi SCM45ZS-W Multi Air Conditioning
Miitsubishi SCM45ZS-W multi air conditioningwww.saturnsales.co.uk
I've asked for multiple outdoor units as I may want to use heat and cold at the same time however rare the occurrence.
My mother is bedbound after having a stroke and heart attack. I've taken over her old upstairs bedroom and moved Mum downstairs for easier access for stretchers etc. I'm considering having these fitted so I sleep better overnight and she is more comfortable overall.
I've contacted the company and asked if they can offer any of the higher models with wifi and auto 3d etc and he says he'll re-quote shortly.
