Looks like my receiver is on its way out, as it's started making random static hisses, crackles and pops. I've tried various things like unplugging all sources, individually disconnecting speakers, unplugging everything else from the socket, but doesn't seem to make any difference.
It's a cheap and cheerful Denon x540bt, and is pretty much exactly 5 years old, so I guess it's not too surprising that it's dying.
I don't need anything fancy to be honest.
* 4 inputs (Sky, Nvidia Shield, Switch, Media PC)
* 4k/HDR (60hz is fine as my TV doesn't support higher)
* We only use the front stereo & centre speakers - room layout doesn't really allow for rear surrounds, but it's handy having the centre speaker so we can turn it up for dialogue when we're watching stuff at night and don't want to wake the kids, so I guess a stereo receiver would be fine if it was able to decode 5.1 and boost the centre channel before sending to the L&R channels (if that's even a thing?)
* No sub needed
* Max 375mm deep, 550mm width, 200mm height.
Current speakers are Mordaunt Short Ms Avant 902 for the L&R, some little Onkyo thing which came with a kit for the centre (yes I know I should get a decent centre speaker to match the sides
The Onkyo TXSR393 Richer Sounds have for £400 is looking like the most suitable new option so far (although quite a bit more than I was hoping to spend), but wondering if there is a more sensible suggestion, either new or used?
Tried the whole soundbar thing and was very disappointed - couldn't get sound and video to sync up at all, and the audio quality didn't really offer any improvement over the TV built in speakers (if anything it made it worse, dialogue was extremely difficult to hear at lower volumes!)
* No sub needed
)The Onkyo TXSR393 Richer Sounds have for £400 is looking like the most suitable new option so far (although quite a bit more than I was hoping to spend), but wondering if there is a more sensible suggestion, either new or used?
