- 7 Sep 2020
- Gods Country
you are a geniusFind the IP address that DHCP has given your laptop then swap homrassistant in that URL above with the IP.
Check out Hildebrand Glow (DCC) Integration. If you sign up to Bright (play store) it connects to your smart meters via the big data warehouse in the cloud. It's only every 30 mins but can give you reasonable usage stats on gas and electricity.
i have bright app already - but i need to learn all this stuff...its alien to me, but i will get thereCheck out Hildebrand Glow (DCC) Integration. If you sign up to Bright (play store) it connects to your smart meters via the big data warehouse in the cloud. It's only every 30 mins but can give you reasonable usage stats on gas and electricity.
Yeah as anything, takes a little while then it becomes less stressful and quite fun.i have bright app already - but i need to learn all this stuff...its alien to me, but i will get there
i need to install hacs first, as i dont have it installed currentlyYeah as anything, takes a little while then it becomes less stressful and quite fun.
Does it give you export data too??Check out Hildebrand Glow (DCC) Integration. If you sign up to Bright (play store) it connects to your smart meters via the big data warehouse in the cloud. It's only every 30 mins but can give you reasonable usage stats on gas and electricity.
But just wait until you get it working, you'll be able to achieve unlimited levels of madness.....how can you add yaml code if you dont have supervisor in HA.... i have a sensor that needs to be reconfigured from power to energy, but i need to add the yaml code for it to work
Looks like i need a newer version of HA.....aaahhhhhhhhh its a headache lol
www.instagram.com
Love it, great work!!
I was just thinking about doing the same!
What's your relay/valves that you've used??
I'm new to HA but have done some tinkering but it does seem sluggish at times, and my log does show lots of warnings - fairly often it will lose bluetooth and hence knock out govee humidity/temp bluetooth sensorsi have finally got a new raspberry Pi4 for decent money..... lets re-do the HA journey
I've got one for the Fire 10...I'm new to HA but have done some tinkering but it does seem sluggish at times, and my log does show lots of warnings - fairly often it will lose bluetooth and hence knock out govee humidity/temp bluetooth sensors
I have it running on a pi 3b+ running from an external SSD and I think the RAM usage is close to capacity. Do you you think its worth updating to pi4 for stability?
KIOSK
Secondly, I have an amazon fire 7 kicking around doing nothing, and would like a permanent display for home assistant display (now that my smart meter IHD is redundant due to not being able to cope with changing daily electricity costs).
Has anyone repurposed a kindle to be a HA display/kiosk? Any good guides?
Well now that's fairly straight forward. I might give the fire toolbox a go first as the fire7 is pretty sluggish. I've seen guides with pages of info on how to actually link kiosk and HA with integrations and the like - what did you do, or did you simp just put the HA URL and left it on the Lovelace dashboard?I've got one for the Fire 10...
Make a wall mounted control panel for your Home Assistant – Hands on Katie
Ever wanted to make your smart home smarter? With this guide, transform your Kindle Fire 10 into a sleek wall-mounted Home Assistant touch screen using a custom 3D printed frame. Let’s get started!handsonkatie.com
Hopefully you might get some ideas from this and obviously PM me if any extra questions/bits not clear!![]()
Yes exactly right, really simple really just load the URL and that's it - there's a few tweaks you can make for convenience (eg I use the webcam to wake the tablet when I pass, but purely optional).Well now that's fairly straight forward. I might give the fire toolbox a go first as the fire7 is pretty sluggish. I've seen guides with pages of info on how to actually link kiosk and HA with integrations and the like - what did you do, or did you simp just put the HA URL and left it on the Lovelace dashboard?
