Apologies, just got caught in the rest of the RT bickering posts.My post was deleted for "RT bickering" ?
It's not as bad as the 4060 Ti but nor is it anything approaching an exciting card, barely a generational leap and more typical of what you've see with a refresh.
Higher IPC, ai matrix accelerators, and various improvements to both raytraced and rasterised IPC. Some features are currently redundant until supported by developers (if they ever are)What's the difference between rdna 2 and 3? Based on this card, I'm inclined to say nothing. I thought at least the ray tracing and power efficiency would be better.
Power efficiency was always going to be a no since while it is s monolith it's only 6nm which is as far as TSMC have said is a cheaper 7nm. Cheaper because in the fab it has fewer steps.What's the difference between rdna 2 and 3? Based on this card, I'm inclined to say nothing. I thought at least the ray tracing and power efficiency would be better.
Sounds like AMD has a personnel problem rather than a hardware issue. Given their size they really should have some top quality people running these things.Steve Burke said something interesting, AMD had a panic attack with this launch, it was pushed out a little early and price cut last minute.
And typically AMD these days a bit botched, apparently some reviewers were sent the wrong drivers, others sent drivers that are months old and aren't even for RDNA3.
The performance on some of these drivers is lower than it should be, some of the review results are inconsistent, the best one is Steve's, it almost matches the RX 6700XT and 4060Ti in a couple of instances and just seems overall faster than a couple of other reviewers. the highest performance it scores vs the 6600 its replacing was +37%, that's not bad.
I think maybe wait for an AIB review with other reviewers before passing final judgement because $270 is not a bad price and if its actually more than the 15 to 20% faster than the 6600 that some reviews show its a better proposition.
Nah, look at all the results with RT. It's mostly around a 10% gain (total performance). That CP2077 result looks borked. Even in Witcher 3 w/ RT the 7600 has only a 12% perf. advantage. The real benchmark for RT in terms of a stable release and optimised around AMD that we can look at, is Metro Exodus EE, and even then we see the same thing 11%.Power efficiency was always going to be a no since while it is s monolith it's only 6nm which is as far as TSMC have said is a cheaper 7nm. Cheaper because in the fab it has fewer steps.
RT is a fair bit better than RDNA2 though, at least in some tiles:
AMD Radeon RX 7600 im Test: Taktraten, Benchmarks in Full HD mit und ohne RT
AMD Radeon RX 7600 im Test: Taktraten, Benchmarks in Full HD mit und ohne RT / Die Taktraten unter Lastwww.computerbase.de
Not going to try and use an image hosting site on the phone, but if you filter their chart to min percentages and Cyberpunk only then versus the 6650 you get around 270%.
Still unplayable and 4060 To is almost twice as fast, but AMD have done something for RT with RDNA3.
Solid midrange card? Wtf am i reading.Measley extras - YOU were slating AMD for not having AV1, not they have it - you dismiss it. Such the strawman. Card is a solid midrange card, cheaper than the one it replaces, and a solid performance increase. Sorry its not a 4090 beater for £250
This is just as bad as the 4060ti. And midrange? More like low end.
they do what papi jensen tells them to doYeah, this is silly,
On the GPU side AMD seem to be stumbling from blunder to blunder, they just can't seem to get that house in order, i don't get it, with all this money they have now can't they hire some industry management guru to grab this by the scuff of the neck and sort it all out?
Come on AMD you're better than this.
