- 25 Nov 2005
So the MSI cable is pretty pointless if it can come loose after you've plugged it in, unless you're looking at it everyday to make sure it's all the way in but then it doesn't solve any problem if you're having to check it constantlyit doesn't seem to take much to rock it out of position even when its supposedly plugged in properly.
(disclaimer - not my pic!)
