- 20 Oct 2002
- Oxfordshire / Bucks
using the same silly strap again :/
I've got a cheap skullcap attachment on the back along with the powerbank, really like the original strap now.I switched back to the stock strap a few weeks ago because I was showing the headset to a few different people. It's actually better than I remembered. The only real problem is the lack of a counter weight. The Elite strap without the battery and every other after market strap without a counter weight have the same issue as the stock strap. After a while they get very uncomfortable because of how front heavy the headset is. Since I changed to the stock strap, I have been using a counter weight and it's been fine even with long gaming sessions.
Since the Quest 3 is going to be way lighter than the Quest 2, I think the stock strap, even without a counter weight, will probably be fine.
Didn't see that! There were rumours that they were going to release a separate cheaper headset.From £499 though on the Meta Quest website. Ouch. Thought there was talk it would be cheaper than the Quest 2 haha
Will there be any improvements to PC connection in terms of compression or work the same? Also the new lenses and bit higher resolution would probably make more difference than you'd think possibly?
The q3 will be 500 not 400, so will cost you 250I'm buying it 100% i'm really looking forward to it, i have no hmd for room scale games at present having sold my Q2 a month or 2 ago in preparation for buying a Q3. I got iirc £250 for my Q2 meaning in effect the Q3 will cost me £150. I can't see it not being a substantial improvement over a Q2 tbh (and imo the Q2 is/was excellent).
correct, my bad.The q3 will be 500 not 400, so will cost you 250
thx! i finally have access to MM now, it only took 10 yearsNo worries
Oh and congrats on 1000 posts
What concerns me re higher resolution though is the PC has to then be able to drive it. Its a struggle now where only a 4090 can really drive the Q2 to its upper limits.Will there be any improvements to PC connection in terms of compression or work the same? Also the new lenses and bit higher resolution would probably make more difference than you'd think possibly?
