- 2 Dec 2020
Thx - will do!
Meant to add - old machine is not Win 11 compatable on many levels so thats not an option either ...
I had loads of issues using the Marvel controller on my x58 board and while it was good to get the higher speeds it was unstable, crashing and more hassle than it was worth.same as ed209 said
way back then i always used the intel sata ports
Good luck, let us know how you get onOk - have now checked all SATA ports and all are now in Intel (blue ones not white). I have 3 HDD and 1 SSD connected so will try SSD first (connected to SATA 0) and if that fails then will try an HDD.
Will format all drives when installing so going in clean - presume Windows 11 will download what it needs to in terms of drivers (if any).
Plan to install Win 11 ISO off Rufus bypass setup USB ...
Wish me luck ...
This is a good shout. Enable only the USB stick and the SSD/HDD as the boot devices and make sure the USB is first. Also check that the Marvell controller is disabled now that you're not using it.Long shot - but have a look at any BIOS settings relating to floppy drives. Either completely disable them if they aren't already, or go the other way and set them to enabled/auto etc.
I've known this to be a rare issue where the installer hangs (although last time I saw it was Windows 7 I think)
You're right there. I remember once installing Windows with another drive temporarily plugged for some reason (probably my backup). When I restored the files from my backup, I unplugged the drive and suddenly I couldn't get back into Windows. Even plugging the backup drive back in again didn't work. Reinstalling Windows twice wasn't exactly what I was hoping for.There’s a first mistake. Only keep the single drive you want windows to be installed on first, then once windows is booted and you happy, shut it down and add the slave drives 1 by 1 just to make sure they working and formatted properly.
Not 100% sure if this still applies but having loads of drives in when installing windows boot info can be wrote to other disks and when you disconnect that drive in future in may stop windows from booting. It can be fixed but bit of a pain to be doing it when it could have been prevented in the first place.
Someone will correct me if it’s not the case with windows 11 any more.
Good luck.
