Does 2.5Gbps Get Hot?
31 Jan 2022
UK
I was just looking at a new switch and wondered (mainly through boredom) whether it was worthwhile getting a 2.5g switch. There is no real advantage of using 2.5g for me, but it's fun. One thing, though, is I wouldn't want to go in that direction if it runs a lot hotter and uses a lot more power. I know 10g runs pretty toasty, but I am not sure about 2.5g?
They do run hotter than gigabit switches. There is no way around that. I've been looking at getting one for a while as I could benefit from it, but prices are still too high for me as a hobbyist. I would say that if you will not benefit from it then there isn't much point spending £100+ on a switch when you can get a Gigabit one for £20.
It's probably a bad time to buy, as well. I see rumours of many more new products where all ports are 2.5g.
Oh, yes, I just read a review for one, the review says it gets hot, which probably means you could cook and egg on it. It's not too bad, but does consume about 3 to 6 times the power of a normal 1gbps switch.
Unless you absolutely need one at the minute which I doubt 99.99% of home users do, I'd just wait for the new range of 2.5g switches tbh.
We probably won't see £20 models anytime soon but with a bit more competition they should drop below £100 eventually.
Mine doesn't run hot.
My Zyxel XGS1210-12 switches run pretty hot, work well though. Just need a bit of air flow.
have 1Gb virgin but if you use these super hub 5, it comes with a 2.5gbe port. They over provision the speed and I actually get 1.3Gb speeds. So 30% for free, cant complain.
The ZYXEL MG-105 is a 5 port 2.5Gb switch and can be had for £69.99 so they are coming down
It's not quite the same, but have the QNAP QSW-2104-2T, a 4x 2.5g and 2x 10g RJ45 (unmanaged) switch. And got it mounted on the wall with plenty of ventilation around it, it barely warm to the touch.
