Even a general purpose polish like Autoglym Super Resin Polish will likely reduce the appearance of most of the paint damage. For the plastic trim, some plastic/vinyl dressing, or even tyre dressing is probably all you can really do
Great video, I have used the two bucket method a handful of times just seems an unnecessary step. I remember watching that video when I first got back into washing / detailing our cars. I now tend use one bucket with grit guard at the bottom, with a couple of different mitts and haven’t had any issues.I’ll let someone else do 11 minutes of waffling about the touchy subject
Heres why the 2 bucket wash method is pointless
Use a good Prewashhttps://tinyurl.com/534hn4r8Use Chenille Noodleshttps://amzn.to/3fhm2w5--------------------------------------------------------------------...youtu.be
I'm guessing you have a hose for rinsing? I thought 2 bucket method was largely for when you only really have buckets.Great video, I have used the two bucket method a handful of times just seems an unnecessary step. I remember watching that video when I first got back into washing / detailing our cars. I now tend use one bucket with grit guard at the bottom and haven’t had any issues.
When I have done family and friends cars I pull out the 2nd bucket. Belts and braces approach that’s it really.
Oh of coarse a complete separate bucket, what is just a cheap B & Q one for the wheels.
I didn’t go much on Auto finesse lather, nothing wrong per se, cleans well although it’s a low foam from memory. I just prefer Chemical Guys Citrus Wash and Gloss for the summer and something generic like Autoglym shampoo and conditioner for the winter as it was cheap.
Yeah I bought a bottle a few year back during a sale and just didn’t rate it. Perhaps I wasn’t putting enough in.I didn’t use it during the wash today, I’ll give it a go next week.
I used it a couple of years ago and had no complaints although I tend to use more than the suggested amount usually.
You should give it a go. Shampoo is the one product that is used frequently, I’ve tried many different brand over years but wash & gloss stood out to me.Perhaps, I’ll update next week!
Never had anything Chemical Guy’s - Seems expensive unless bought in bulk.
The above kit as it’s on offer costs only a couple of pounds more than 473ML of Chemical Guys Shampoo
Usually I’m not fussy with car shampoo, if it’s rubbish then it was probably cheap and I just use more to produce the slickness and suds.
www.cleanyourcar.co.uk
Yeah its leather. probably going to get it redone soon as some stitiching has failed at the top half of the wheel but the wheel doesnt feel nice to use in its current stateIs it actually leather or leather imitation?
Autoglym Leather Care Balm 500ml | Halfords UK
Shop the latest The Autoglym Leather Care Balm provides great protection for your leather seats. at Halfords UKwww.halfords.com
@MrRockliffe
My brother has recently bought a new car which is generally in great condition except from the rear window, it has considerable swirling with a couple of deeper scratches.
I have a DA and would like to attempt to improve the finish for him.
Would Ceriglass have enough cutting power to improve the finish or are fairly deep scratches on a rear tinted window a lost cause?
I’ve never had proper leather only imitation but this stuff is well reviewed.Yeah its leather. probably going to get it redone soon as some stitiching has failed at the top half of the wheel but the wheel doesnt feel nice to use in its current state
I used this/leftYeah its leather. probably going to get it redone soon as some stitiching
You’re thinking of the cream, not the cleaner. Creams and conditioners are little use on modern leathers as they are all ‘clear coated’, they just need cleaning. Any conditioner will just sit on top and cause the greasiness.
load of BS he's doing two buckets wrong - you don't do it if the car is completely caked in mud, you work downwards from the roof/bonnet for the pre-wash to avoid contamination and ensure dirt runs off.I’ll let someone else do 11 minutes of waffling about the touchy subject
