So for anyone who wants to run Sorcerer, this is the build I'm running. I levelled a fair amount of the way with a Frost build, but it's rather slow and this "Icetricity" build is much faster and clears packs by freezing them - which makes them vulnerable - applying burn and then whacking them with Charged bolts which simply *nukes* groups in no time at all.
The main build is:
5/5 Arc Lash + Enhanced + Glinting
5/5 Charged Bolts + Enhanced + Greater
1/5 Flame Shield + Enhanced + Shimmering
1/5 Teleport + Enhanced + Shimmering
1/5 Frost Nova + Enhanced + Mystical
Your Ultimate is Unstable Currents + Prime + Supreme
You want 1/5 Firebolt for the first Enchantment and Arc Lash for the Second - this adds burn damage to your attacks and an AoE stun when you use a cooldown.
You then want to add in 1 Static Discharge and 3 Shocking Impact, followed by filling out the Coursing Currents tree making sure you 3/3 Convulsions.
*Important* This build really needs the Helm Ability "Frost Nova gains an additional charge...." to function. Without it, it's really not as good, but with it, it's amazing.
Other recommended abilities:
"Your casts of Charged Bolt have a 15% chance to be attracted to enemies and last 300% longer"
"You deal 51% more damage to immobilized, stunned or frozen enemies" - you will always be triggering this.
"When you freeze an enemy there is a 27% chance they become vulnerable for 3 seconds".
If you try this, let me know how you get on.
