When is the best time to start an alt? Should I progress to get the mount on my main first? I'm like level 22 at the moment, enjoying my class, but would like to try the others though. Or should I complete the main story completely so I can skip the story on alts?
Handy to know, I've only been upgrading my armor and not the rings\amuletI was wondering why I couldn't upgrade my rings/amulets, but turns out you need to upgrade them at the gem person...
I got to level 70 without upgrading any of my jewellery!![]()
So for anyone who wants to run Sorcerer, this is the build I'm running. I levelled a fair amount of the way with a Frost build, but it's rather slow and this "Icetricity" build is much faster and clears packs by freezing them - which makes them vulnerable - applying burn and then whacking them with Charged bolts which simply *nukes* groups in no time at all.
The main build is:
5/5 Arc Lash + Enhanced + Glinting
5/5 Charged Bolts + Enhanced + Greater
1/5 Flame Shield + Enhanced + Shimmering
1/5 Teleport + Enhanced + Shimmering
1/5 Frost Nova + Enhanced + Mystical
Your Ultimate is Unstable Currents + Prime + Supreme
You want 1/5 Firebolt for the first Enchantment and Arc Lash for the Second - this adds burn damage to your attacks and an AoE stun when you use a cooldown.
You then want to add in 1 Static Discharge and 3 Shocking Impact, followed by filling out the Coursing Currents tree making sure you 3/3 Convulsions.
*Important* This build really needs the Helm Ability "Frost Nova gains an additional charge...." to function. Without it, it's really not as good, but with it, it's amazing.
Other recommended abilities:
"Your casts of Charged Bolt have a 15% chance to be attracted to enemies and last 300% longer"
"You deal 51% more damage to immobilized, stunned or frozen enemies" - you will always be triggering this.
"When you freeze an enemy there is a 27% chance they become vulnerable for 3 seconds".
If you try this, let me know how you get on.![]()
Anyone playing with a controller? I just cant play with mouse clicks on ground it just doesn't feel right to me
This is almost identical to the Arc lash build on Maxroll. Been nurfed a bit because of the stuns but some peeps reporting it still strong later on when you're geared.
I play on my xbox. Controller is great but as you say the distance is a little tricky on some skills. My ice sorc sometimes drops a blizzard or ice blades too far or not far enough. I very occasionally drop them completely wrong if I'm running around using skills.yeah it's really good for controller, just a few builds struggle with aiming, it's not directional aiming issue more a distance aiming issue
Clicking and dragging mouse works for movement also. I don't like this method however as you don't hist the carts and other objects on the ground that have little bits of loot.Anyone playing with a controller? I just cant play with mouse clicks on ground it just doesn't feel right to me
