Previous owners ran a feed to the shed for pond pump ect, they used swa (steel wire armoured) with a plug fitted at the house end. First thing I did was to buy an RCD. Better safe than sorry.
Just buy some second hand 2.5mm, potentially 4mm, armoured cable, take it off a socket in the house and then add a socket the other end. Done properly then and no one is doing to dig through it.
because the OP says he wants too.....just leaving it trailing along the garden or grass etc would look unsightly.Why is anyone at all recommending burying an extension lead in conduit? So much effort for a bodge job.
Yes it is a bodge job because it isn't outdoor grade cable (atmospheric conditions is what will eat the copper) and plumber waste pipe isn't resilient to a spade. Burying it half assed is more dangerous than leaving it above ground as an extension lead. Source: I used to trail an extension lead to charge my electric car.because the OP says he wants too.....just leaving it trailing along the garden or grass etc would look unsightly.
And is it really a bodge job.
Armoured cable isn't even that expensive. If you're going to the bother of digging (through the concrete as well?), use the right type of cable at least. Even if it's not properly terminated at the ends.
You put it behind an FCU not just straight off the socket, that would be acceptable in the house for a single double gang socket only.don't really like the idea of going off a socket,
Burying an extension lead in plastic plumbing pipe? Yes it really is a bodgeAnd is it really a bodge job.
its underground, what atmospheric conditions will eat the copper.......i have had electric cable tacked to my fence from an outdoor socket, run down to my shed to use tv, computer, wifi etc etc now for 10yrs....copper not been eaten by anythingYes it is a bodge job because it isn't outdoor grade cable (atmospheric conditions is what will eat the copper) and plumber waste pipe isn't resilient to a spade. Burying it half assed is more dangerous than leaving it above ground as an extension lead. Source: I used to trail an extension lead to charge my electric car.
Aye lad they just make outdoor grade for fun.its underground, what atmospheric conditions will eat the copper.......i have had electric cable tacked to my fence from an outdoor socket, run down to my shed to use tv, computer, wifi etc etc now for 10yrs....copper not been eaten by anything
Next door neighbour has the same running to his hottub for over 20yrs pinned to his fence....copper not been eaten either. So your casing point doesnt hold water im afraid.
is it....if its never going to be dug up again, then whats the issue...the OP knows its there and if he ever leaves the house or sells it he can remove the sockets from both ends and pull the cable out.Burying an extension lead in plastic plumbing pipe? Yes it really is a bodge![]()
they make outdoor grade to buried if its never going to be dug back up or struck by a digging tool....the OP is putting it underground against the wall in his own garden, so should know its there if hes doing other work in the future.Aye lad they just make outdoor grade for fun.
Why do people put so much effort into doing things objectively wrong?Why do people need to make mountains out of mole hills....
but its not objectively wrong, its just different to what you would do and if you look at many forums over the internet, there are many people that do it the same way and many people that would do it another way.........Why do people put so much effort into doing things objectively wrong?
crack on fella....it wont be an issue, but you will always get naysayers in life, they make lots of noise for no reason, than just to be heard.I was debating popping this on here as I knew it would get some comments ha! Its cost me £15 in total and probably about a half day's work. Like I said it's just for ease of use, no putting extensions away at night. No access to my garage unless the door was open. I often pop out so thought this would be a nice simple idea. Guess not! I don't really need to buy armored cable if this is in conduit clipped to the wall? I will not be burying it. The cable is free as I will be using an outdoor extension. There is no concrete digging, it's an easy job.
Why even bother with conduit? Just run the cable if that is your plan.I was debating popping this on here as I knew it would get some comments ha! Its cost me £15 in total and probably about a half day's work. Like I said it's just for ease of use, no putting extensions away at night. No access to my garage unless the door was open. I often pop out so thought this would be a nice simple idea. Guess not! I don't really need to buy armored cable if this is in conduit clipped to the wall? I will not be burying it. The cable is free as I will be using an outdoor extension. There is no concrete digging, it's an easy job.
