AMD software on non admin w11 user
10 Jan 2009
Just set up new PC with 6700xt, my w11 user account is admin. I've set up my daughters account as non admin. When I log into her account it doesn't show AMD settings, just wondering if I've set up fan profile on my account will it carry over to her account? Also same for Fan Control software, I've set up fan curves for PC case fans, will they carry when she logs into her account.
Possibly the AMD and fan control software are not configured to run at startup for your daughters account !?! If you can start them via the start menu and they appear to work as intended afterwards you can just add shortcuts to them into the startup group for the account (Windows + R for run dialogue enter shell:startup in the run box to bring up the startup group & add your shortcuts). I don't believe the AMD software will have your settings in so you may need to configure it to be the same as yours.
This is GREAT info, will try it tonight. You are correct they don't start up for her account.
All AMD GPU setting carried over to daughters profile, for fan control has to run it from start and just used config file from my profile. All good now, put both software to start up when she logs in.
