I'm not sure I understand this. I don't think I've ever seen an app that uses one of the Android gestures to access menu's? Am I being dim? Android gestures are all about controlling the app surely, not what goes on in the app? I guess some might build a gesture in themselves, but that's not down to Android?The problem is that Android, for many years, has used gestures for opening menus and other interactions within apps.
Or in the Gmail app the side menu flies out. But it's hard to do since the back gesture kicks in. You can get the menu to fly out if you go slow and go at an angle.Swiping goes back?
Swiping in has never been an action to open the hamburger menu? It's back. If the menu was the last place you were in, it would go back to it, of course...As I’ve been an Android user for so long, and because some apps still use the hamburger menu, it’s engrained in me to swipe in to open it.
Swiping goes back?
I would fall into that camp of not even really knowing/using the menu gesture, which I think from analytics Google is saying most people didn't us it. Everyone goes back. But they should have removed one when they brought the other.Google has already explained that the back action is a core part of Android and is used even more often than the home action, so assigning an intuitive and reliable gesture was crucial for this system. Many longtime Android users disagree, but Google says the vast majority of Android users didn’t even know a swipe could open up side menus as most would simply tap a button within the app.
Do we have Pixel 8 thread yet?
Google Pixel 8 camera leak details new main sensor, Pro-only upgrades, more
The camera has always been the best feature of Google’s Pixel smartphones, and according to a detailed new leak, the...9to5google.com
The biggest detail here is a new primary camera sensor for both phones, the Samsung ISOCELL GN2. This 50MP sensor is the direct successor to the GN1 that Pixel 6 and 7 use, and also the same sensor used in Samsung’s Galaxy S22 and S23
Same here which is quite amusing as I had the "New Pixel features" screen popup after the reboot just to tell me about all this things that I've not got yetJust got the June update on my 7Pro, but I don't have any of the new features. No Cinematic wallpaper, no emoji wallpaper and no macro video.
Great update lol
Yeah that's what I'm thinking lolSame here which is quite amusing as I had the "New Pixel features" screen popup after the reboot just to tell me about all this things that I've not got yet
Assuming they'll be activated by individual app updates over the coming days.
I've seen a number of articles pop up about the latest update tanking battery.Phone signal and battery life seems to have taken a hit with the last update… anyone else or is it likely a “me” issue?
Ah ok thanks fingers crossed something will be updated soon then!I've seen a number of articles pop up about the latest update tanking battery.
Some Google Pixel phones have excessive battery drain after June Feature Drop
A few people also face connectivity issues following the updatewww.androidpolice.com
Some Pixel owners are experiencing faster battery drain after June update
You're not alone if you're seeing aggressive battery drain and spotty mobile network coverage.www.xda-developers.com
