Fallout 4 CPU benchmark thread(need some Zen3 and Zen4 results!)
Man. It doesn't look like I bought myself much.
11700 -- 60
8000 -- 73
RX 6800 (Came from 1070....0 (zero) fps diff)
Ryzen 5 7600 (Came from 4770k.....20fps diff)?
XPG LANCER RGB DDR5 Desktop Memory: 32GB (2x16GB) 6000 MHz CL40-40-40​
My previous results.
11700 -- 40fps.
8000 -- 47fps.
DDR3/RX 6800/4770k.
The result seems kinda low.....
My ram was NOT at 6000Mhz. It was at something considerably lower, like 4200Mhz, with who knows what kinda of timings.
More or less I've had an under clock on my ram since my new build for awhile now. Doing the F4 benches, seems to have brought it to light.
I did Cinebench single core to check. Closer to the 7600 than any other proc, so I'm good there. Now I'm running the XMP profile on that above ram correctly.
11700 -- 70fps
8000 -- 83fps
7600 Stock. Rx 6800 Stock. DDR5 6000Mhz CL40-40-40.
Not too shabby. Bought myself +10fps by just getting my ram speed/timings right. Previous result was under-clocked DDR5.
11700 -- 70fps
8000 -- 83fps
Well, in terms of rankings it moves you to #51 vs #63 of the score with the JEDEC DDR5. Your older Intel 4770K ranking was #76 (right at the bottom just above my 3570K with a RX 470).
As to why yours is still low? I'm afraid everything points to AMD's driver overhead for DX9/10/11 versus Nvidia (for DX12 things are largely reversed).
If we look at people who had run the benches with both GeForce and Radeon, we get a table like this:
Which is all rather unfortunate as aside from Nvidia's last two '90 cards, I'd rather have the AMD cards due needing the VRAM (some Wabbajack Skyrim SE modlists actually recommend 16GB of VRAM and have a min of 12GB or so).
@bobharris without swapping your card for a GeForce we will never know, but your both average of 76.5 / 0.87 would get you around 88 which is top ten here.
Problem, I suspect, is that for the price of your 6800 you would only have got a 3070 whose 8GB is borderline so IMO the 6800 was the correct choice.
Quick thought. I do have a 1070 in the closet, my prev GPU. Would that give you another data point?
It might be interesting if it's not too much trouble as we don't have any R5 7600 with Nvidia results.
I'm sure at actual playing resolutions there are probably big differences with the driver code of the 10x0 series and recent cards, but at low resolution like here it probably doesn't matter.
Thing is, it would only be academic as even with the overhead difference, I don't suppose you want to go back to an 8GB Pascal card!
You have the same score as my 13600k results mate.
Opps, sorry. Copy and paste error, almost the same indeed!
Corrected it above, and here's the top 10:
So that's better. Number 4, probably without BLK overclocking like yuke and even faster memory it is hard to get much higher.
I keep including the S1/S2 ratio in the hope that it tells us something about drawcall vs NPCs (as CoreVega should have far more NPCs), but while there is variation I am unsure it means much.
It's outside and most of the NPCs are spread out in a large area - Diamond City has a lot of NPCs in a relative small area.
3400G w/Vega 11 - Stock CPU speed
16GB (minus whatever for the APU) @3000mhz 22/21/21/50 (Cheap SODIMMS FTW)
Corvega - 35.7fps (11,721 dc)
Diamond City - 41.4fps (8,013 dc)
ENB v0.489
Probably close to one of the existing 13700KF or 13600K results:
Is there any hope that at 13700K@5.5 GHz DDR4 3200CL14 I will get 100 FPS on Corvega? This may seem ridiculous to someone, but I need an upgrade specifically for Fallout 4. Otherwise, my 9900K suits me. And if so, is it better to look towards 7800x3D and 6000CL14 anyway?
I did a similar test 5 years ago on 3930K and 8700K.
I'll copy straight from there:
3930K @ 4.5 GHz / DDR3 @ 2400 MHz (9-11-11-31-1T) / GTX 980 Ti @ 1455/7900 MHz
Corvega: Draw Calls: 11704 / FPS: 60.9 / Diamond City: Draw Calls: 8025 / FPS: 72.3
8700K @ 4.8 GHz / 3000-14-15-15-30-T1 / GTX 980 Ti @ 1455/7900 MHz
Corvega: 81.6 FPS / Diamond City: 95.8 FPS
8700K @ 4.8 GHz / 3500-17-17-17-35-T2 / GTX 980 Ti @ 1455/7900 MHz
Corvega: 80.4 FPS / Diamond City: 95.7 FPS
8700K @ 4.8 GHz / DDR4 3000-17-17-17-35-T2 / GTX 980 Ti @ 1455/7900 MHz
Corvega: 75.9 FPS / Diamond City: 90.3 FPS
8700K @ 4 GHz / 3500-17-17-17-35-T2 / GTX 980 Ti @ 1455/7900 MHz
Corvega: 70.9 FPS / Diamond City: 83.5 FPS
But if I had 81 FPS on 8700K@3000CL14, wouldn't 100FPS be too low on 13th-gen?
ENB v0.489
Nice try, but at being slowest my old score with my i5 3570K + Radeon 470 is still unbeaten!
Damn, I was hoping to get some sort of trophy :D
I've actually tightened the RAM timings so it might even be faster than that now.
I wonder how using a discrete GPU could/would raise the score due to not having to hit the gfx part of the chip (see the 4700 vs 4650 results)
EDIT: Quick check with updated timings, could tighten more but I've not got the time or desire to mess any more :D
16GB (minus whatever for the APU) @3000mhz 18/17/17/45
Corvega - 36fps (11,685 dc)
Diamond City - 44.5fps (7,994 dc)
ENB v0.489
I don't get it. Why not just share the table via google spreadsheet? Using image for navigation is very inconvenient for obvious reasons.
Well, Google sheets (and OpenOffice / Libre office Calc) aren't really able to do conditional formatting as well.
I did look at no registration required free online spreadsheet programs but they were even worse.
Google Sheets is far fancier but you have to sign up and can't use it anonymously AFAIK.
