Caporegime
- 1 Dec 2010
- Welling, London
“What was you doing when you saw the Titanic?”
”Having a ****”
”Having a ****”
There is a window in the section that also serves as a makeshift toiletSeems insane when you look at it like that, what is the point if there aren't any windows![]()
If that happens, let's hope they can be spotted bobbing about on the surface because they're not getting out without someone to undo the bolts from the outside.
£200k to sit in a bog with 4 other people?You can look out the window where the toilet is?
So what, you open it and pee out of it?
It’s not a “bog” it’s more a hole in the floor and a privacy curtain. So if no one using it; then it’s just a window at the front of the vessel and the hole is covered up. That’s how I understand it.£200k to sit in a bog with 4 other people?
Are we at conspiracy theory stage yet?
Apparently there isn’t a single rescue vessel that can go anything like as deep as 4Km, the max is about 1Km so if they are indeed stuck on the bottom - there’s practically no hope…
What an awful situation, 96 hours too…
Yes and I also have a much better lifestyle than you, taller better looking more intelligent and great views from my houseFlying is one of the safest forms of travel, do you ever even leave the house?
Simon Platts, who directed a BBC documentary episode about the Titan sub last year, said if the vessel was on the water surface it would be really hard to spot.
He said normally the sub comes to the surface and gets in touch with the mother vessel, before they both travel towards each other.
It is a "very small thing in a big ocean" because only the top of the sub floats above the sea level, he said.
Aww sorry you don't understand stats, stick to your crayons maybe?Uneducated people don't understand stats, so that's about 80% of the UK.
Crayons are above my risk tolerance.Aww sorry you don't understand stats, stick to your crayons maybe?
