Micro-freezing issue
31 Jul 2019
I'll start with the usual "hope this is the right forum" bit as I couldn't see we have a general troubleshooting one on here.
My PC has this ongoing issue that I can only describe as micro-freezing, where the system just stops for a fraction of a second - no mouse movement, can't type etc. This comes on a fresh install of W11 - it was doing it during the install process so it leads me to think it's something hardware causing the problem.
Up until Friday evening, I was running W10 where the issue was worse - the system would either freeze entirely (display on screen but everything completely frozen) or cause the PC to reboot by itself. It's been going on for a while so I don't think it's the current heat that's the problem. As I'd decided to reinstall Windows, I figured I'd take the opportunity to go onto W11 - I've not had a full freeze or reboot, just the micro freezing.
Any ideas on where to look to solve the problem? Or any more information I can provide?
Temps are good at about 32C across all cores - huge case, plenty of air flow.
Ryzen 5 3600X @ stock
MSI B450 Tomahawk Max
16GB Patriot Viper Steel DDR4 3600 (2 x 8GB)
Sabrent Rocket M.2
Gigabyte RTX 3070 (Latest drivers)
Here's the output from CPU-Z
Thank you!
EDIT: Perhaps my PSU is something to investigate? A Corsair TX850 purchased in September 2009.
Processors
CPU Groups1
CPU Group 012 threads, mask=0xFFF
Number of sockets1
Number of threads12
APICs
Socket 0
-- Node 0
-- CCD 0
-- CCX 0
-- Core 0 (ID 0)
-- Thread 00
-- Thread 11
-- Core 1 (ID 1)
-- Thread 22
-- Thread 33
-- Core 2 (ID 2)
-- Thread 44
-- Thread 55
-- CCX 1
-- Core 3 (ID 4)
-- Thread 68
-- Thread 79
-- Core 4 (ID 5)
-- Thread 810
-- Thread 911
-- Core 5 (ID 6)
-- Thread 1012
-- Thread 1113
Timers
ACPI timer3.580 MHz
Perf timer10.000 MHz
Sys timer1.000 KHz
Processors Information
Socket 1ID = 0
Number of cores6 (max 6)
Number of threads12 (max 12)
Number of CCDs1
ManufacturerAuthenticAMD
NameAMD Ryzen 5 3600X
CodenameMatisse
SpecificationAMD Ryzen 5 3600X 6-Core Processor
PackageSocket AM4 (1331)
CPUIDF.1.0
Extended CPUID17.71
Core SteppingMTS-B0
Technology7 nm
TDP Limit95.0 Watts
Tjmax95.0 蚓
Core Speed3599.2 MHz
Multiplier x Bus Speed36.0 x 100.0 MHz
Base frequency (cores)100.0 MHz
Base frequency (mem.)100.0 MHz
Instructions setsMMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
Microcode Revision0x8701021
L1 Data cache6 x 32 KB (8-way, 64-byte line)
L1 Instruction cache6 x 32 KB (8-way, 64-byte line)
L2 cache6 x 512 KB (8-way, 64-byte line)
L3 cache2 x 16 MB (16-way, 64-byte line)
Max CPUID level00000010h
Max CPUID ext. level80000020h
FID/VID Controlyes
# of P-States3
P-StateFID 0x898 - VID 0x48 (38.00x - 1.100 V)
P-StateFID 0xA8C - VID 0x58 (28.00x - 1.000 V)
P-StateFID 0xC84 - VID 0x68 (22.00x - 0.900 V)
PStateReg0x80000000-0x49920898
PStateReg0x80000000-0x47160A8C
PStateReg0x80000000-0x459A0C84
PStateReg0x00000000-0x00000000
Package Type0x2
Model00
String 10x0
String 20x0
Page0x0
Power Unit0.0
SMU Version46.67.00
TDP/TJMAX0x5F005F
TCTL Offset0x0
PMTV00240903
Min Frequency550 MHz
Max Frequency4400 MHz
VID Limit1.4750 Volts
PBO Scalar1
Package Power Tracking (PPT)Current : 128.0 W, fused : 128.0 W
Thermal Design Current (TDC)Current : 80.0 A, fused : 80.0 A
Electrical Design Current (EDC)Current : 125.0 A, fused : 125.0 A
Temperature 032 degC (89 degF) (Package)
Temperature 130 degC (85 degF) (CCD #0)
Temperature 230 degC (85 degF) (Cores (Max))
Temperature 329 degC (84 degF) (Core #0)
Temperature 430 degC (85 degF) (Core #1)
Temperature 529 degC (84 degF) (Core #2)
Temperature 628 degC (83 degF) (Core #3)
Temperature 729 degC (84 degF) (Core #4)
Temperature 828 degC (83 degF) (Core #5)
Temperature 929 degC (84 degF) (L3 Cache #0)
Temperature 1029 degC (84 degF) (L3 Cache #1)
Temperature 1131 degC (87 degF) (SoC)
Voltage 01.02 Volts (VID)
Voltage 11.03 Volts (CPU VDD)
Voltage 21.02 Volts (SoC VDD)
Power 0021.97 W (Package)
Power 012.47 W (Cores)
Power 020.58 W (Core #0)
Power 030.68 W (Core #1)
Power 040.61 W (Core #2)
Power 050.11 W (Core #3)
Power 060.47 W (Core #4)
Power 070.03 W (Core #5)
Clock Speed 03599.16 MHz (Core #0)
Clock Speed 13599.16 MHz (Core #1)
Clock Speed 23599.16 MHz (Core #2)
Clock Speed 33599.16 MHz (Core #3)
Clock Speed 43599.16 MHz (Core #4)
Clock Speed 53599.16 MHz (Core #5)
Core 0 max ratio(effective) 41.25
Core 1 max ratio(effective) 41.25
Core 2 max ratio(effective) 41.25
Core 3 max ratio(effective) 41.25
Core 4 max ratio(effective) 41.25
Core 5 max ratio(effective) 41.25
Chipset
NorthbridgeAMD Ryzen SOC rev. 00
SouthbridgeAMD B450 rev. 51
Bus SpecificationPCI-Express 3.0 (8.0 GT/s)
Graphic InterfacePCI-Express 4.0
PCI-E Link Widthx16 (max 16x)
PCI-E Link Speed2.5 GT/s (max 16.0 GT/s)
Memory TypeDDR4
Memory Size16 GBytes
Channels2 x 64-bit
Memory Frequency1066.4 MHz (3:32)
Memory Max Frequency1600.0 MHz
CAS# latency (CL)15.0
RAS# to CAS# delay (tRCD)15
RAS# Precharge (tRP)15
Cycle Time (tRAS)36
Bank Cycle Time (tRC)51
Command Rate (CR)1T
Uncore Frequency1066.4 MHz
Memory SPD
DIMM #1
SMBus address0x52
Memory typeDDR4
Module formatUDIMM
Module Manufacturer(ID)Patriot Memory (7F7F7F7F7F020000000000000000)
SDRAM Manufacturer (ID)SK Hynix (AD00000000000000000000000000)
Size8192 MBytes
Max bandwidthDDR4-3602 (1801 MHz)
Max JEDECDDR4-2133 (1066 MHz)
Part number3600 C17 Series
Nominal Voltage1.20 Volts
EPPno
XMPyes, rev. 2.0
AMPno
EXPOno
JEDEC timings tableCL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #110.0-10-10-25-35 @ 733 MHz
JEDEC #211.0-11-11-27-38 @ 800 MHz
JEDEC #312.0-13-13-30-42 @ 900 MHz
JEDEC #413.0-14-14-32-45 @ 966 MHz
JEDEC #514.0-14-14-35-49 @ 1033 MHz
JEDEC #615.0-15-15-36-50 @ 1066 MHz
JEDEC #716.0-15-15-36-50 @ 1066 MHz
XMP profileXMP-3602
SpecificationDDR4-3602
VDD Voltage1.350 Volts
Min Cycle time0.555 ns (1801 MHz)
Max CL17.0
Min tRP10.55 ns
Min tRCD10.55 ns
Min tRAS21.61 ns
Min tRC37.74 ns
Min tRRD5.53 ns
XMP timings tableCL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #19.0-11-11-21-36-n.a @ 953 MHz (1.350 Volts)
XMP #211.0-13-13-26-44-n.a @ 1165 MHz (1.350 Volts)
XMP #312.0-14-14-28-48-n.a @ 1271 MHz (1.350 Volts)
XMP #413.0-15-15-30-52-n.a @ 1377 MHz (1.350 Volts)
XMP #514.0-16-16-33-56-n.a @ 1483 MHz (1.350 Volts)
XMP #615.0-17-17-35-60-n.a @ 1589 MHz (1.350 Volts)
XMP #716.0-18-18-37-64-n.a @ 1695 MHz (1.350 Volts)
XMP #817.0-19-19-39-68-n.a @ 1801 MHz (1.350 Volts)
XMP #918.0-19-19-39-68-n.a @ 1801 MHz (1.350 Volts)
XMP #1019.0-19-19-39-68-n.a @ 1801 MHz (1.350 Volts)
XMP #1120.0-19-19-39-68-n.a @ 1801 MHz (1.350 Volts)
DIMM #2
SMBus address0x53
Memory typeDDR4
Module formatUDIMM
Size8192 MBytes
EPPno
XMPyes, rev. 2.0
AMPno
EXPOno
XMP profileXMP-3602
Max CL17.0
Min tRP10.55 ns
Min tRCD10.55 ns
Min tRAS21.61 ns
Min tRC37.74 ns
Min tRRD5.53 ns
Monitoring
Mainboard ModelB450 TOMAHAWK MAX (MS-7C02) (0x00000677 - 0x129436B4)
LPCIO
LPCIO VendorNuvoton
LPCIO ModelNCT6797
LPCIO Vendor ID0x5CA3
LPCIO Chip ID0xD4
LPCIO Revision ID0x51
Hardware Monitors
Hardware monitorNuvoton NCT6796
Voltage 81.14 Volts [0x8E] (CPU VCORE)
Voltage 91.22 Volts [0x4C] (DRAM)
Voltage 1012.29 Volts [0x80] (+12V)
Voltage 115.12 Volts [0x80] (+5V)
Voltage 131.03 Volts [0x81] (NB/SoC)
Voltage 153.38 Volts [0xD3] (+3.3V)
Temperature 633 degC (91 degF) [0x21] (System)
Temperature 732 degC (89 degF) [0x20] (CPU)
Temperature 843 degC (109 degF) [0x2B] (PCH)
Temperature 1036 degC (96 degF) [0x24] (MOS)
Fan 1682 RPM [0x2AA] (CPU)
Fan 31018 RPM [0x3FA] (SYS fan 2)
Fan 4956 RPM [0x3BC] (SYS fan 3)
Hardware monitorAMD Ryzen Power Management
Temperature 029 degC (84 degF) [0x1D] (Core #0)
Temperature 030 degC (85 degF) [0x1D] (Core #1)
Temperature 029 degC (84 degF) [0x1D] (Core #2)
Temperature 028 degC (83 degF) [0x1C] (Core #3)
Temperature 029 degC (84 degF) [0x1D] (Core #4)
Temperature 028 degC (83 degF) [0x1C] (Core #5)
Temperature 029 degC (84 degF) [0x1D] (L3 Cache #0)
Temperature 029 degC (84 degF) [0x1D] (L3 Cache #1)
Temperature 031 degC (87 degF) [0x1E] (SoC)
Hardware monitorNVIDIA NVML
Power 0117.32 W (GPU)
Hardware monitorNVIDIA NVAPI
Power 0118.34 W (GPU)
Clock Speed 0210.00 MHz [0xD2] (Graphics)
Clock Speed 1405.00 MHz [0x195] (Memory)
Clock Speed 2n.a. (Processor)
PCI Devices
DescriptionHost Bridge
Locationbus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID0x1022 (AMD)
Model ID0x1480
Revision ID0x00
PCI header
Subvendor ID0x1462 (MSI)
Subsystem ID0x7C02
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Model ID0x1482
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
DescriptionPCI to PCI Bridge
Locationbus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Model ID0x1483
Revision ID0x00
PCI header
Primary bus0x00
Secondary bus0x01
Int. Line0xFF
Int. Pin0x00
PCI capability
Caps classPower Management
Caps offset0x50
Caps version1.2
PCI capability
Caps classPCI Express
Caps offset0x58
Device typeRoot Port of PCI-E Root Complex
Port1
Caps version2.0
Physical slot#0
Presence detectyes
Link width4x (max 4x)
Link speed8.0 GT/s (max 8.0 GT/s)
PCI capability
Caps classMessage Signalled Interrupts
Caps offset0xA0
PCI capability
Caps classSubsystem Vendor
Caps offset0xC0
SubVendor ID0x1022 (AMD)
SubSystem ID0x1234
PCI capability
Caps classHyperTransport
Caps offset0xC8
Interface typeMSI Mapping
Locationbus 0 (0x00), device 1 (0x01), function 3 (0x03)
Common header
Model ID0x1483
Revision ID0x00
PCI header
Primary bus0x00
Secondary bus0x03
Int. Line0xFF
Int. Pin0x00
PCI capability
Caps offset0x50
Caps version1.2
PCI capability
Caps offset0x58
Port0
Caps version2.0
Physical slot#0
Presence detectyes
Link width4x (max 8x)
PCI capability
Caps offset0xA0
PCI capability
Caps offset0xC0
SubSystem ID0x1234
PCI capability
Caps offset0xC8
Locationbus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Model ID0x1482
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
Model ID0x1482
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 3 (0x03), function 1 (0x01)
Common header
Model ID0x1483
Revision ID0x00
PCI header
Primary bus0x00
Secondary bus0x26
Int. Line0xFF
Int. Pin0x00
PCI capability
Caps offset0x50
Caps version1.2
PCI capability
Caps offset0x58
Port0
Caps version2.0
Physical slot#0
Presence detectyes
Link width16x (max 16x)
Link speed2.5 GT/s (max 8.0 GT/s)
PCI capability
Caps offset0xA0
PCI capability
Caps offset0xC0
SubSystem ID0x1234
PCI capability
Caps offset0xC8
Locationbus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Model ID0x1482
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 5 (0x05), function 0 (0x00)
Common header
Model ID0x1482
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Model ID0x1482
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 7 (0x07), function 1 (0x01)
Common header
Model ID0x1484
Revision ID0x00
PCI header
Primary bus0x00
Secondary bus0x27
Int. Line0xFF
Int. Pin0x01
PCI capability
Caps offset0x50
Caps version1.2
PCI capability
Caps offset0x58
Port0
Caps version2.0
Physical slotIntegrated device
Link speed16.0 GT/s (max 16.0 GT/s)
PCI capability
Caps offset0xA0
PCI capability
Caps offset0xC0
SubVendor ID0x7C02
SubSystem ID0x1462
PCI capability
Caps offset0xC8
Locationbus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Model ID0x1482
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 8 (0x08), function 1 (0x01)
Common header
Model ID0x1484
Revision ID0x00
PCI header
Primary bus0x00
Secondary bus0x28
Int. Line0xFF
Int. Pin0x01
PCI capability
Caps offset0x50
Caps version1.2
PCI capability
Caps offset0x58
Port0
Caps version2.0
PCI capability
Caps offset0xA0
PCI capability
Caps offset0xC0
SubVendor ID0x7C02
SubSystem ID0x1462
PCI capability
Caps offset0xC8
DescriptionSMBus Controller
Locationbus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
Model ID0x790B
Revision ID0x61
PCI header
Subsystem ID0x7C02
Int. Line0x00
Int. Pin0x00
DescriptionPCI to ISA Bridge
Locationbus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
Model ID0x790E
Revision ID0x51
PCI header
Subsystem ID0x7C02
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Model ID0x1440
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Model ID0x1441
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Model ID0x1442
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Model ID0x1443
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 24 (0x18), function 4 (0x04)
Common header
Model ID0x1444
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 24 (0x18), function 5 (0x05)
Common header
Model ID0x1445
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 24 (0x18), function 6 (0x06)
Common header
Model ID0x1446
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
Locationbus 0 (0x00), device 24 (0x18), function 7 (0x07)
Common header
Model ID0x1447
Revision ID0x00
PCI header
Subvendor ID0x0000
Subsystem ID0x0000
Int. Line0x00
Int. Pin0x00
DescriptionNVM Express (NVMe) Controller
Locationbus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID0x1987
Model ID0x5012
Revision ID0x01
PCI header
Address 0 (memory)0x00000000FC700000
Subvendor ID0x1987
Subsystem ID0x5012
Int. Line0x00
Int. Pin0x01
PCI capability
Caps offset0x80
Device typePCI-E Endpoint Device
Port1
Caps version2.0
PCI capability
Caps classMSI-X
Caps offset0xD0
PCI capability
Caps offset0xE0
PCI capability
Caps offset0xF8
Caps version1.2
DescriptionUSB Controller (xHCI)
Locationbus 3 (0x03), device 0 (0x00), function 0 (0x00)
Common header
Model ID0x43D5
Revision ID0x01
PCI header
Address 0 (memory)0x00000000FC6A0000
Subvendor ID0x1B21 (ASMedia)
Subsystem ID0x1142
Int. Line0x00
Int. Pin0x01
PCI capability
Caps offset0x50
PCI capability
Caps offset0x78
Caps version1.2
PCI capability
Caps offset0x80
Device typeLegacy PCI-E Endpoint Device
Port0
Caps version2.0
DescriptionSerial ATA Controller - AHCI
Locationbus 3 (0x03), device 0 (0x00), function 1 (0x01)
Common header
Model ID0x43C8
Revision ID0x01
PCI header
Address 5 (memory)0xFC680000
Subsystem ID0x1062
Int. Line0x00
Int. Pin0x02
PCI capability
Caps offset0x50
PCI capability
Caps offset0x78
Caps version1.2
PCI capability
Caps offset0x80
Port0
Caps version2.0
Locationbus 3 (0x03), device 0 (0x00), function 2 (0x02)
Common header
Model ID0x43C6
Revision ID0x01
PCI header
Primary bus0x03
Secondary bus0x20
Int. Line0x05
Int. Pin0x03
PCI capability
Caps offset0x50
PCI capability
Caps offset0x78
Caps version1.2
PCI capability
Caps offset0x80
Device typeUpstream Port of PCI-E Switch
Port0
Caps version2.0
PCI capability
Caps offset0xC0
SubVendor ID0x1B21 (ASMedia)
SubSystem ID0x0201
Locationbus 32 (0x20), device 0 (0x00), function 0 (0x00)
Common header
Model ID0x43C7
Revision ID0x01
PCI header
Primary bus0x20
Secondary bus0x21
Int. Line0x0B
Int. Pin0x01
PCI capability
Caps offset0x50
PCI capability
Caps offset0x78
Caps version1.2
PCI capability
Caps offset0x80
Device typeDownstream Port of PCI-E Switch
Port0
Caps version2.0
Physical slot#0
Presence detectno
Link width0x (max 1x)
Link speed2.5 GT/s (max 5.0 GT/s)
PCI capability
Caps offset0xC0
SubSystem ID0x3306
Locationbus 32 (0x20), device 1 (0x01), function 0 (0x00)
Common header
Model ID0x43C7
Revision ID0x01
PCI header
Primary bus0x20
Secondary bus0x22
Int. Line0x0A
Int. Pin0x01
PCI capability
Caps offset0x50
PCI capability
Caps offset0x78
Caps version1.2
PCI capability
Caps offset0x80
Port1
Caps version2.0
Physical slot#0
Presence detectyes
Link width1x (max 1x)
PCI capability
Caps offset0xC0
SubSystem ID0x3306
Locationbus 32 (0x20), device 4 (0x04), function 0 (0x00)
Common header
Model ID0x43C7
Revision ID0x01
PCI header
Primary bus0x20
Secondary bus0x25
Int. Line0x0B
Int. Pin0x01
PCI capability
Caps offset0x50
PCI capability
Caps offset0x78
Caps version1.2
PCI capability
Caps offset0x80
Port4
Caps version2.0
Physical slot#0
Presence detectno
Link width0x (max 4x)
PCI capability
Caps offset0xC0
SubSystem ID0x3306
DescriptionEthernet Controller
Locationbus 34 (0x22), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID0x10EC (Realtek)
Model ID0x8168
Revision ID0x15
PCI header
Address 0 (port)0x0000F000
Address 2 (memory)0x00000000FC504000
Address 4 (memory)0x00000000FC500000
Subsystem ID0x7C02
Int. Line0x00
Int. Pin0x01
PCI capability
Caps offset0x40
Caps version1.2
PCI capability
Caps offset0x50
PCI capability
Caps offset0x70
Port0
Caps version2.0
Link speed2.5 GT/s (max 2.5 GT/s)
PCI capability
Caps classMSI-X
Caps offset0xB0
DescriptionVGA Controller
Locationbus 38 (0x26), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID0x10DE (NVIDIA)
Model ID0x2484
Revision ID0xA1
PCI header
Address 0 (memory)0xFB000000
Address 1 (memory)0x00000000D0000000
Address 3 (memory)0x00000000E0000000
Address 5 (port)0x0000E000
Subvendor ID0x1458 (GIGABYTE)
Subsystem ID0x404C
Int. Line0x00
Int. Pin0x01
PCI capability
Caps offset0x60
Caps version1.2
PCI capability
Caps offset0x68
PCI capability
Caps offset0x78
Port0
Caps version2.0
Link speed2.5 GT/s (max 16.0 GT/s)
PCI capability
Caps classVendor Dependant
Caps offset0xB4
DescriptionHigh Definition Audio (HDA)
Locationbus 38 (0x26), device 0 (0x00), function 1 (0x01)
Common header
Model ID0x228B
Revision ID0xA1
PCI header
Address 0 (memory)0xFC080000
Subsystem ID0x404C
Int. Line0x37
Int. Pin0x02
PCI capability
Caps offset0x60
Caps version1.2
PCI capability
Caps offset0x68
PCI capability
Caps offset0x78
Port0
Caps version2.0
DescriptionNon-Essential Instrumentation Device
Locationbus 39 (0x27), device 0 (0x00), function 0 (0x00)
Common header
Model ID0x148A
Revision ID0x00
PCI header
Subsystem ID0x7C02
Int. Line0xFF
Int. Pin0x00
PCI capability
Caps offset0x48
PCI capability
Caps offset0x50
Caps version1.2
PCI capability
Caps offset0x64
Port0
Caps version2.0
Locationbus 40 (0x28), device 0 (0x00), function 0 (0x00)
Common header
Model ID0x1485
Revision ID0x00
PCI header
Subsystem ID0x7C02
Int. Line0xFF
Int. Pin0x00
PCI capability
Caps offset0x48
PCI capability
Caps offset0x50
Caps version1.2
PCI capability
Caps offset0x64
Port0
Caps version2.0
DescriptionEncryption Device
Locationbus 40 (0x28), device 0 (0x00), function 1 (0x01)
Common header
Model ID0x1486
Revision ID0x00
PCI header
Address 2 (memory)0xFC300000
Address 5 (memory)0xFC408000
Subsystem ID0x7C02
Int. Line0x05
Int. Pin0x01
PCI capability
Caps offset0x48
PCI capability
Caps offset0x50
Caps version1.2
PCI capability
Caps offset0x64
Port0
Caps version2.0
PCI capability
Caps offset0xA0
PCI capability
Caps classMSI-X
Caps offset0xC0
Locationbus 40 (0x28), device 0 (0x00), function 3 (0x03)
Common header
Model ID0x149C
Revision ID0x00
PCI header
Address 0 (memory)0x00000000FC200000
Subsystem ID0x7C02
Int. Line0x00
Int. Pin0x03
PCI capability
Caps offset0x48
PCI capability
Caps offset0x50
Caps version1.2
PCI capability
Caps offset0x64
Port0
Caps version2.0
PCI capability
Caps offset0xA0
PCI capability
Caps classMSI-X
Caps offset0xC0
Locationbus 40 (0x28), device 0 (0x00), function 4 (0x04)
Common header
Model ID0x1487
Revision ID0x00
PCI header
Address 0 (memory)0xFC4F8000
Subsystem ID0xEC02
Int. Line0x24
Int. Pin0x04
PCI capability
Caps offset0x48
PCI capability
Caps offset0x50
Caps version1.2
PCI capability
Caps offset0x64
Port0
Caps version2.0
PCI capability
Caps offset0xA0
DMI
SMBIOS Version2.8
DMI BIOS
vendorAmerican Megatrends International LLC.
version3.A0
date02/03/2021
ROM size16384 KB
DMI System Information
manufacturerMicro-Star International Co. Ltd
productMS-7C02
version1.0
serialTo be filled by O.E.M.
UUID{91A9128C-0896-3916-ACB5-00D861A65582}
SKUTo be filled by O.E.M.
familyTo be filled by O.E.M.
DMI Baseboard
vendorMicro-Star International Co. Ltd
modelB450 TOMAHAWK MAX (MS-7C02)
revision1.0
serialJ816706458
DMI System Enclosure
chassis typeDesktop
chassis serialTo be filled by O.E.M.
DMI Extension Slot
designationJ6B2
typePCI Express
populatedyes
DMI Extension Slot
designationJ6B1
typePCI Express
populatedyes
DMI Extension Slot
designationJ6D1
typePCI Express
populatedyes
DMI Extension Slot
designationJ7B1
typePCI Express
populatedyes
DMI Extension Slot
designationJ8B4
typePCI Express
populatedyes
DMI Extension Slot
designationJ8D1
typePCI Express
populatedyes
DMI Extension Slot
designationJ8B3
typePCI
width32 bits
populatedyes
DMI OEM Strings
string[0]To be filled by O.E.M.
DMI Physical Memory Array
locationMotherboard
usageSystem Memory
correctionNone
max capacity128 GB
max# of devices4
DMI Processor
manufacturerAdvanced Micro Devices Inc.
modelAMD Ryzen 5 3600X 6-Core Processor
clock speed3800.0 MHz
FSB speed100.0 MHz
multiplier38.0x
max clock speed4400.0 MHz
DMI data
0000x04 0x30 0x17 0x00 0x01 0x03 0x6B 0x02 0x10 0x0F
0100x87 0x00 0xFF 0xFB 0x8B 0x17 0x03 0x8B 0x64 0x00
0200x30 0x11 0xD8 0x0E 0x41 0x31 0x14 0x00 0x15 0x00
0300x16 0x00 0x04 0x05 0x06 0x06
DMI Memory Device
designationDIMM 0
formatunknown
typeunknown
speed2133 MHz
manufacturerUnknown
part numberUnknown
serial numberUnknown
manufacturer id0x3020
product id0x5000
DMI data
0000x11 0x28 0x19 0x00 0x11 0x00 0x18 0x00 0xFF 0xFF
0100xFF 0xFF 0x00 0x00 0x02 0x00 0x01 0x02 0x02 0x04
0200x00 0x55 0x08 0x03 0x04 0x00 0x05 0x00 0x00 0x00
0300x00 0x00 0x55 0x08 0x00 0x00 0x00 0x00 0x00 0x00
0400x44 0x49 0x4D 0x4D 0x20 0x30 0x00 0x50 0x30 0x20
0500x43 0x48 0x41 0x4E 0x4E 0x45 0x4C 0x20 0x41 0x00
0600x55 0x6E 0x6B 0x6E
DMI Memory Device
designationDIMM 1
formatDIMM
typeDDR4
total width64 bits
data width64 bits
size8 GB
speed2133 MHz
manufacturerUnknown
part number3600 C17 Series
serial number00000000
voltage1.200000
manufacturer id0x3120
product id0x5000
DMI data
0000x11 0x28 0x1B 0x00 0x11 0x00 0x1A 0x00 0x40 0x00
0100x40 0x00 0x00 0x20 0x09 0x00 0x01 0x02 0x1A 0x80
0200x40 0x55 0x08 0x03 0x04 0x00 0x05 0x01 0x00 0x00
0300x00 0x00 0x55 0x08 0xB0 0x04 0xB0 0x04 0xB0 0x04
0400x44 0x49 0x4D 0x4D 0x20 0x31 0x00 0x50 0x30 0x20
DMI Memory Device
designationDIMM 0
formatunknown
typeunknown
speed2133 MHz
manufacturerUnknown
part numberUnknown
product id0x5000
DMI data
0000x11 0x28 0x1E 0x00 0x11 0x00 0x1D 0x00 0xFF 0xFF
0500x43 0x48 0x41 0x4E 0x4E 0x45 0x4C 0x20 0x42 0x00
DMI Memory Device
designationDIMM 1
formatDIMM
typeDDR4
total width64 bits
data width64 bits
size8 GB
speed2133 MHz
manufacturerUnknown
voltage1.200000
product id0x5000
DMI data
0000x11 0x28 0x20 0x00 0x11 0x00 0x1F 0x00 0x40 0x00
DMI Port Connector
designationJ1500 (internal)
designationUSB 3.0 (external)
port typeUSB
connectorAccess Bus (USB)
DMI Port Connector
designationJ1501 (internal)
port typeUSB
DMI Port Connector
designationJ1502 (internal)
designationUSB-C (external)
port typeUSB
DMI Port Connector
designationJ1503 (internal)
port typeUSB
DMI Port Connector
designationJ1504 (internal)
designationUSB 3.1 (external)
port typeUSB
DMI Port Connector
designationNetwork (external)
port typeNetwork Port
connectorRJ-45
DMI Port Connector
designationJ1704 (internal)
designationSata Express (external)
DMI Port Connector
designationJ1705 (internal)
DMI Port Connector
designationJ1701 (internal)
designationiSATA (external)
DMI Port Connector
designationJ1702 (internal)
DMI Port Connector
designationJ1703 (internal)
DMI Port Connector
designationJ1706 (internal)
DMI Port Connector
designationJ1100 (internal)
designationHDMI (external)
port typeVideo Port
DMI Port Connector
designationJ1101 (internal)
port typeVideo Port
DMI Port Connector
designationJ1102 (internal)
designationDP (external)
port typeVideo Port
DMI Port Connector
designationJ2100 (internal)
designationFront Audio (external)
port typeAudio Port
connectorMini Jack (headphones)
DMI Port Connector
designationJ2101 (internal)
designationAudio Jack (external)
port typeAudio Port
DMI Port Connector
designationJ1700 (internal)
DMI Extension Slot
designationJ10
typePCI Express
populatedyes
DMI Extension Slot
designationJ3600 Pcie x8 slot
typePCI Express
populatedno
DMI Extension Slot
designationJ3707 Pcie x4 slot
typePCI Express
DMI Extension Slot
designationJ3700 PCIE x4 slot from Promontory
typePCI Express
populatedno
DMI Extension Slot
designationJ3702 PCIE x1 slot from Promontory
typePCI Express
populatedno
DMI Extension Slot
designationJ3703 PCIE x1 slot from Promontory
typePCI Express
populatedno
DMI Extension Slot
designationJ3701 M.2 WLAN/BT slot
typePCI Express
populatedyes
Graphics
Number of adapters1
Graphic APIs
APID3D
APINVIDIA I/O
APINVIDIA NVML
APINVIDIA NVAPI
pwrMask0x000C9CF3
pwrTable[F5 F6 00 00 FF FA FC E8 00 00 FE F6 F1 00 00 E0 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 ]
Display Adapters
Display adapter 0
ID0x10B0104
NameNVIDIA GeForce RTX 3070
Board ManufacturerGIGABYTE Technology
RevisionA1
CodenameGA104-300
Core family0x174 (GA104-A)
Power Limit270.0 W (current), 270.0 W (default), 270.0 W (max)
Thermal Limit93.0 蚓 (max), 95.0 蚓 (slowdown), 98.0 蚓 (shutdown)
Cores5888
ROP Units96
TM Units368
RayTracing Cores46
Tensor Cores184
Technology8 nm
Memory typeGDDR6 (Samsung)
Memory size8 GB
Memory bus width256 bits
PCI devicebus 38 (0x26), device 0 (0x0), function 0 (0x0)
Vendor ID0x10DE (0x1458)
Model ID0x2484 (0x404C)
Revision ID0xA1
Root devicebus 0 (0x0), device 3 (0x3), function 1 (0x1)
Performance LevelBase
Core clock1500.0 MHz
Memory clock7001.0 MHz
Performance LevelBoost
Core clock1815.0 MHz
Performance LevelCurrent
Core clock210.0 MHz
Memory clock405.0 MHz
Driver version31.0.15.3623
WDDM Model3.1
Win32_VideoControllerAdapterRAM = 0xFFF00000 (4293918720)
Win32_VideoControllerDriverVersion = 31.0.15.3623
Win32_VideoControllerDriverDate = 06/08/2023
Monitor 0
ModelPL3461WQ (Idek Iiyama)
IDIVM7615
Serial1171801500839
Manufacturing DateWeek 15, Year 2020
Size34.1 inches
Max Resolution3440 x 1440 @ 75 Hz
Horizontal Freq. Range217-217 kHz
Vertical Freq. Range48-144 Hz
Max Pixel Clock800 MHz
Gamma Factor2.2
Software
Windows VersionMicrosoft Windows 11 (10.0) Home 64-bit (Build 22621)
DirectX Version12.0
Nothing in the event viewer when it does it?
What USB devices do you have?
Any spare HDD/SSD?
  • Like
Reactions: sg0
I'll check the event viewer in W11. I didn't notice anything in particular in W10 other than a general warning about computer not having shut down properly, or something along those lines.
USB only has keyboard and mouse, via monitor, and the flash drive with the W11 install.
No clicks, pops, cracks or bangs heard.
first guess... ftpm module 'issues' with amd on windows
Might be fixed by turning it off and/or newer bios
BIOS update from some 2021 version to most recent version appears to have fixed the issue. Now that I know where to look, I can see the internet had something to say about this issue!
Cheer boss!
