OR FTTP was recently made available in my area in April so I've had that installed (900/100 via Aquiss) and kept the previous VM 1.1Gbps and split devices between them using PBR and failover to the other if needed.
The FTTP service is 6 to 14ms less latency than VM as expected with FTTP being 6ms most of the time with little variation which is great, however I am surprised that the FTTP has more dropouts than VM. In the 6 weeks since install I've had three short FTTP dropouts (less than 5mins) after midnight and a fault that dropped the connection for 7 hours. In contrast over the last few years the VM service drops out around once every 2 - 3 months for a few minutes usually in the early hours.
The longer fault could be a one off, but are shorter dropouts common as I was expecting similar if not better uptime than VM? I do some online backups overnight and am keeping them via VM as oddly its the more reliable service at the moment!
