Yeah when I look at the quality of my neighbours 4k cameras as well, which he paid less than half the price for... well yeah its hard to justify.Thanks - that's the issue. Want the 4K cameras but paying nearly the same price as a UDM SE is simply outrageous.
I’ve got a G4 door bell and 4 G5 cameras (2 dome, 2 bullet) all running off a cloud key gen2+.
From my perspective the protect app is very good and has come a long way since I started with the door bell a few years ago. You also have local control via web browser.
For a plug and play setup that runs fully locally if needed, you’ll be hard pushed for better.
Do you actually need 4K cameras? The picture quality on the G5 is good enough for what is designed to do if the correct camera is selected.
Even the proper CCTV people recommend 5mp over 8mp cameras these days.
I'm not impressed with the g5s night vision so far, but I wonder if I just need to tinker with the settings a bit or perhaps placement isn't great. It's ~5 metres from the door I'm trying to cover and it doesn't look that clear.Do you actually need 4K cameras? The picture quality on the G5 is good enough for what is designed to do if the correct camera is selected.
With a dome you will get more IR glow, think someone posted some comparison screenshots in the last page or so.Perhaps the 4K is more of a want but not fussed about RAID/redundancy or backup, likely only going to have 2 or 3 cameras. A deterrent, coverage and ability to alert us whilst away will do nicely.
So a G5 Bullet or Dome then? I see the Dome says it's vandal resistant - how so? Leaning towards the Dome for the wide angle as it would be covering the whole front/off street parking.
Difference between a G4 and G5 Dome seems very minimal (SoC with the 4 having an older one but it's quad core and FPS).
That was me, I’ve taken them down already though.With a dome you will get more IR glow, think someone posted some comparison screenshots in the last page or so.
The bullet is directly wall mountable, the dome will need a bracket if it’s going on a wall.Perhaps the 4K is more of a want but not fussed about RAID/redundancy or backup, likely only going to have 2 or 3 cameras. A deterrent, coverage and ability to alert us whilst away will do nicely.
For most cases, an AC Lite will more than suffice. Easy to buy them used too. If buying new, it makes sense to go for a U6 Lite. As mentioned previously, if one AP doesn't provide the required coverage, then easy enough to add in a second.Fair point! The third floor isn’t going to be occupied properly for a while so i will definitely add a second AP on the top floor my office will be up there so there will be a cable or two run anyway.
What would be the simplest access point to start off with?
Great thanks was thinking I’d go new as the chances are it’s going to be in my house for so long the investment will be worth it. Just need to add a POE switch now as it will be much easier than using injectors near the devices. I was looking at something like the TP-Link TL-SG108PE seems like it will do the job and will probably cover all the connections I need 99% of our stuff is wireless hence investing in that and just running cables to a couple of key positions (home office and TV locations)For most cases, an AC Lite will more than suffice. Easy to buy them used too. If buying new, it makes sense to go for a U6 Lite. As mentioned previously, if one AP doesn't provide the required coverage, then easy enough to add in a second.
Ubiquiti Networks UC-CK Stand-Alone UniFi Cloud Key Controller - WhiteHi @iMacMart what's that UniFi Network device? Is that an old controller? What's the state of it?
Ah, have you tried to fix it? If it's the gen 1 I think they have SD card corruption issues or similar.Ubiquiti Networks UC-CK Stand-Alone UniFi Cloud Key Controller - White
it’s showing as “offline” ?
I’m not 100% sure it is fsilty? Maybe a firmware upgrade broke it? I’ve tried rebooting it, I did tried a backup restore but maybe I didn’t stop the service that I read about? the very last thing I want is to be crawling round the loft space with the heat we’ve had recentlyAh, have you tried to fix it? If it's the gen 1 I think they have SD card corruption issues or similar.
Either fix the device, or replace it. If you replace it, you can restore from your backup.
Good point! So can I factory reset the device and upload a good configuration file? Would that mean the 4 x APLRs will be able to connect again? The wifi is working fine, it’s just the whole UniFi system is brokeIt's most likely a power cut or similar and the BD has corrupted.
