Build Check
11 Mar 2010
Cardiff
Hey,
Looking for someone in the know to cast their eye over this upgrade package I'm looking at, please :)
I currently have an EK based loop consisting of 2x EK-CoolStream PE 240 Dual and a EK-XRES 100 Revo D5, it's cooling an i9 9900K and 2080ti.
It's been fine for near enough 5 years, no issues.
I'm looking at the following to replace the exisiting kit, and keeping the Rads and pump.
Any thoughts or mistakes with the following?
(not looking to order until the 4090 block is in stock)
Cheers.
My basket at OcUK:
Total: £3,057.86 (includes delivery: £0.00)​
£175 (incl. VAT)
£155 (incl. VAT)
£160 (incl. VAT)
£155 (incl. VAT)
£500 (incl. VAT)
£350 (incl. VAT)
  • Like
Reactions: str
Ah good shout, I read up on ATX3 PSU's this evening then added the Corsair/removed a be quiet! and forgot to remove it from a previous basket.
Cheers for taking a look.
Intel alternative just for fun:
My basket at OcUK:
Total: £2,862.90 (includes delivery: £7.99)​
You can see how they compare here:
Unless you're using stuff like blender, unlikely to offer any advantage. You can see benchmarks on that kind of app here.
I would stay away from EK blocks, they have become the Asus of the water cooling world.
When i re built my Loop recently in the same situation as you (new mboard,cpu and gcard) i went with the Corsair XC7 cpu block and an alpha cool GPU block, previously i was using all EK blocks but the “ek tax” just isn't worth it now
Now days most of the WC stuff is within a degree or two of each other
Annoyingly OCUK dont sell the alphacool block for your card but you can check the correct one on the comparability site and find it. I wont link the exact block as will fall foul of the forum rules but its much cheaper.
Thanks for the input, much appreciated.
Did you reuse the connectors/fittings you had previously or did you purchase new?
I reused most of my fittings, but replaced all my tubing (i use soft tubing) as changing from coloured to clear coolant.
The only fittings i didn't reuse were barbed ones, half my loop was compression and half were barbs whilst i had it all apart i swapped the rest for compression.
Yep, in the Corsair Carbide Air 540 the PSU is mounted on it's side, so the connectors will face upwards. At least, that's my understanding of it :)
Yes that's correct I just checked they face upwards , I didn't want you buying a PSU with the connectors facing down.
Would have made your build interesting though :D
