Fixing what? A slight revision to the connector by chamfering the pins to make it easier for people to connect? That is user error lol.Sure the last one was grand, it was all user error...now they're fixing it....strange....
Same with Corsair TBH, solid quality.Glad I chucked my aesthetics out of the window for safety by sticking with Seasonics direct cable.
Yep I never expect a reputable PSU brand to skimp on things like connectors and terminals, Just doesn't happen.Same with Corsair TBH, solid quality.
It's definitely good it's getting done but there's not much to it as I expected, The main one which I thought would 99% get done was the shortening of the sense pins to force people to connect their cable properly or it won't boot but these Cablemod adaptors melting are whole new beast and unless Cablemod revise their spec for the adaptor no amount of PCI SIG or Nvidia tweaking their connector is going to fix Cablemods smouldering adaptors.Once enough users err with a given part, the part itself needs to be revised.
This connector needed a revision and I'm glad to see it getting one.
There's a 3x pin one they do? Mine is 16 pin to 2x 8 pin! (type 4 600W spec)
hwbusters.com
The real question remains, what did this bring that a pair of 12Vx8 couldn't provide? It is hardly that these cards are so small that they need a smaller connector.
Can't lie this is what I had to do to get a replacement in the first place for their ****** cable giving me black screens and when the replacement came chucked it straight in the bin lol.The best "mod" I ever did...
Useless garbage.
Since fitting the Corsair 12VHPWR cable I've had zero problems.
Well, so much for my "Guess there are only a four possibilities:" earlier.I’m pretty annoyed by this whole saga, although my 4090 FE has been OK so far, I’m more annoyed that I spent a small fortune on a Seasonic Vertex GX 1200 (the most expensive PSU I ever purchased) only now to find out they are superseding the connections.
I can only assume Seasonic won’t update the cables for those who already have purchased a PSU. Which is just great.
Although painful, I guess you have an ATX 3.0b then - and that after spending a small fortune![]()
The PSU side has probably also changed.
I was going to get the vertex but glad I didn’t in the end and got the be quiet adaptor instead.I’m pretty annoyed by this whole saga, although my 4090 FE has been OK so far, I’m more annoyed that I spent a small fortune on a Seasonic Vertex GX 1200 (the most expensive PSU I ever purchased) only now to find out they are superseding the connections.
