The 5 extra panels get additional shading throughout the day by trees depending on the Suns angle as they are on a lower roof than the others.Are only the five additional panels shaded?
I’m not an expert but near enough 4k for panels that get additional shading sounds a lot. You won’t get the full additional 2kw I don’t think?The 5 extra panels get additional shading throughout the day by trees depending on the Suns angle as they are on a lower roof than the others.
Yep its a lot, but is SolarEdge+optimisers better than a GivEnergy system - I mean its about 3k more. I am thinking its not worth it.I’m not an expert but near enough 4k for panels that get additional shading sounds a lot. You won’t get the full additional 2kw I don’t think?
Can someone advise if option 2 for £3600 extra would be worth it? Half of the panels are in direct sunlight between 7-1pm, the others are shaded then. In the afternoon the other half get sunlight while the first half is shaded.
Thanks, would the SolarEdge kit still be better if the GivEnergy inverter was bigger? I get the feeling SolarEdge is more premium than GivEnergy and the standard warranties are double with SolarEdge.Better output on the SolarEdge kit, no chance of clipping which you could get with the GivEnergy. Continuous output from battery on SolarEdge is 5000w which is decent, and it is NMC so no need to worry about cold temps if putting it in a garage etc.
Perhaps ask them if they could get the second quote down to under £16k?
Option 2 is a steal, the battery alone is in the £7k-£8k range. Solaredge is great, since my instal mid May have not imported hardly anything from Grid 2to 3 kWh!!! 9.88kW panels.I just had some quotes (from the same installer), how do these look and any advice please?
Option 1 - 7.98Kwh:
19 Jinko Tiger Neo 54c 420W N-Type All Black Mono solar panels
GivEnergy 5kW hybrid inverter
Gen2 GivEnergy 9.5kWh LiFePO4 Battery
£13099
Option 2 - 10.08kwh:
24 Jinko Tiger Neo 54c 420W N-Type All Black Mono solar panels
SolarEdge optimisers
SolarEdge 8000 HD Wave
SolarEdge 10kwh Battery
£16699
Both options + extra for bird protection.
Consider adding Tigos optimisers (£40ea IIRC) just to the shaded panels, plus a TAP and CCA for monitoring them (~£200), it will play nicely with the GivEnergy and is much cheaper.Yep its a lot, but is SolarEdge+optimisers better than a GivEnergy system - I mean its about 3k more. I am thinking its not worth it.
So now i've had my solar installed for a year, a bit of a report and a few figures for you.
Installed System 30th June 2022
Estimated Yearly Production 6244kWh
- 17x370w JA Panels (6.29 kWh) 30 degree roof angle - 1 degree off south
- Givenergy Gen 1
- 2 * 8.2kWh Givenergy batteries
Actual Year Production (1st July - 30th June) 6195.4kWh
- Units used directly 2133.5kWh
- Units used to charge battery 2297.3kWh
- Units Exported Directly (from solar) 1764.6kWh
- Actual Grid Out 2128kWh
First year review/summary
Initial use meant I pulled only minimal watts (less than 10 per month) from the Grid through until October 14th, this was the date I established my panels had some shading from next doors roof (which actually started on the 7th October once I'd figured out my installation wasn't failing), initially this was only on the lower string until mid November, and obviously knew this would continue through until a similar time the other side of winter. But as I was on a fixed rate until October 2023, I just used my solar to supplement my usage during the day. My wife had her PHEV delivered in November and so usage ramped up (12.5kWh capacity used 5 or 6 times a week give or take).
Then on 6th December I noticed my outputs etc were 0, went down to inspect my inverter and no lights, nothing, immediately called the installer who came out the following day and confirmed the inverter was dead with some parts visibily burnt out. Not good my inverter lasted 5 months, but good it died when I benefited from the solar the least. The installers reported this to Givenergy who advised it'd take a few weeks to replace the inverter, with Christmas and NY this actually meant 6 weeks as they had had so few failures they wanted to check the installation to see if there is anything that could indicate what causd this. But when replaced they did not, unfortunately they replaced like for like with a Gen 1 inverter.
Since then I've had no issues and when the shading went I have been generating well and moved onto Octopus Flux in April. As I only had the 4p SEG rate from December to April, I missed out on 570 units of export last summer.
As stated elsewhere I've been tracking some rough cost savings and this for the first year is £1006, which with the inverter being out for 7 weeks isn't half bad and doesn't account for the missed export value whilst my SEG was set up. I've calculated these based on the fact I had a fixed rate of 19.5p per kWh until this October which if I didn't get solar I would have stayed on, obviously if I was at the cap I would have saved an extra £600. I also did't charge my batteries up over winter overnight which if I had been on go or similar would have saved even more money at 7.5p/10p per unit. The solar has also enabled me to run my AC 24/7 during the summer months with no panic about how much it was costing, which for the quality of sleep I got was worth it alone!
Going forward with energy prices and current tarriff options I believe more savings will be had in this coming year, with my solar coming out in profit once my Flux account is set up properly. One other piece of good news for my installation is that my neighbours are building an extension which is due to start at the end of July and with this they will be moving the gable of the roof back about 3 or 4 foot and removing the rogue TV aerial, so hopefully my shading time will be reduced by a few week either side of the winter. I may still investigate adding a Gen2 inverter in the future, but for now with my usage and the Flux tarriff my day export can be balanced by the overnight charging, so I will stay with this set up for now.
Do you have solaredge optimisers on yours?Option 2 is a steal, the battery alone is in the £7k-£8k range. Solaredge is great, since my instal mid May have not imported hardly anything from Grid 2to 3 kWh!!! 9.88kW panels.
Generated to date 2.42MWh exported 999kWh to grid.
Change to Octopus Flexible now, and sign up for a smart meter with them, once install complete change to Flux, also now! check with DNO fuse is 80 to 100A better 100A if you can.
The monitoring system is great, also consider SE smart hot water heater which helps you use excess solar to immersion heater. If you use Boost etc then you have 2 apps to mess with, keep it all SE.
YesDo you have solaredge optimisers on yours?
Yes they are currently modifying the SE app. But ensure you make installer gives you installer access as part of the contract, it allows Battery power profiles to be fine tuned for your particular use see this utube video explains a lotjust read up on Flux - wow thanks for that.
Anyone know if the SolarEdge system can be set to charge the battery overnight on cheap rate so the inverter can export as much as possible during the day?
Tigo are not what I wanted, they are not anything like SE optimisers hence the low cost, did extensive research and had maybe 10 home surveys and a lot more armchair google earth surveys, used easy-pv to check etc, so glad I went down the SE route. I have shading early morning from trees and chimney shadows etcbut you wouldn't think so. Since 11th May I have generated 2.49Mwh of which 1.02Mwh exported to grid. I am a heavy user with a pool pump and a daughter part time baking business etc etc The app actually shows each panel and what power it is producing individually.
