Cpu,ram and mobo burning situation?
I would check the dimensions on the 4090 you want to fit into the O11 Air Mini. I built my new mATX in the O11 Air Mini and it's a great case and pretty big for an mATX but it looks like you've got ~20mm clearance to put that card in. I'm not convinced the max clearance Lian Li report includes the two 140mm fans at the front of the case either. The cpu cooler clearance might be a little tight as well. Is there a reason you want to put it all in a small case? The O11 Dynamic EVO is a bit bigger and would seem to house it better.
Other things i read today was that ASUA ROG STRIX X670E-E has a slow boot up time? is this just ASUS or are all boads like this?
also about Armoury crate is in bedded in the motherboard and prompts you to install each time you boot? what?
Armoury crate will ask if you want to install it
If its a new install of Windows
If you tell it no it doesn't ask again
At least with my motherboard that's what it does
I sent an AMD AM5 board back because it's just too risky right now. There is absolutely no way of knowing if boards are being damaged internally because of the fast and loose manner in which mobo makers treat voltages. We saw worse case scenarios recently with actually observable damage. But long term damage could be happening. The way mobo makers handled this makes me believe they have no idea how to fix this yet. The measures issued are quick fixes that may not even address the core issue. I will wait until a definitive fix is issues by AMD. Also, It is likely mobos are being redesigned, even if it's just minor changes, to remove the issue and that will take time for the new boards to arrive in stock. Boards manufactured after May/June this year. I'll try again around October, hopefully all older boards will have been cleared from stock by then.
There's no mess to sort out?
There was a very small amount of cpus that went pop, it was addressed pretty quick and now you're free to buy what you want? Hell, I bought my AM5 kit right when one of them went pop, and turned on expo and started OCing the ram right away :D
