NVIDIA 4000 Series
19 Sep 2009
Riedquat system
I am struggling to stop myself buying a 4090. It is the only card that can really do MSFS justice [edit - in VR]. Can someone come round and slap me down please.
:p
23 Feb 2012
UK
Might be worth waiting on a 4090 until the new 12VHPWR socket is mainstream.
It has been spotted on new 4070 FE cards.
No point buying a 4090 if you can never be sure the power cable or socket will melt, may explain the drop in 4090 sales.
Would you buy a card at £1500 that you can never be sure of its safety.
6 Oct 2007
North West
15 Dec 2010
UK
From what I've read it's the adaptor and aftermarket cables that usually cause this. Stock cables on ATX3.0 PSUs seem ok.
15 Dec 2010
UK
7 Nov 2017
14 Aug 2009
Possibly but give that, PCI-SIG, have chaned the design and we will soon be getting ATX 3.1 PSUs it does sugggest the intial design was flawed.
Maybe it depends how well the connectors were implemented by each IHV.
I play in this one ATM
https://www.palit.com/palit/vgapro.php?id=4688
The adapter that came with it clicks nicely and stays in place - PSU is an old ENERMAX 525W.
But, there's one thing a tdp of 320w and another for 450w.
19 Feb 2007
ArcCorp
Cutting it a little close aren't you ? I know it only draws up to maybe 320 watts but once you factor in your CPU, Cooler, Fans etc... that 525w is looking a bit close.
15 Dec 2010
UK
Apple RAM pricing, innit. :)
Edit: Actually, just checked and it's not even close to Apple's charge of £200 for an extra 8GB of RAM!
Apple memory is constructed with gold, platinum, fairy dust and and unicorn poo. It's very pricey! Come to think of it, this might also be what Nvidia GPUs are now manufactured with, we owe them an apology after all!
