Recommendations for a 10gbps NIC?
RSR
RSR
17 Aug 2006
What medium are you thinking about using?
RJ45 - Copper
Intel X540-T1 (These are older cards now)
Intel X540-T2 (These are older cards now)
Intel X550-T1
Intel X550-T2
I know there is an Intel X7XX but I can't think of a model number off the top of my head)
SFP - OM3/4 - Fibre
Mellanox ConnectX 4
Mellanox ConnectX 5
Intel X710-DA
These are not cheap options but they will perform trouble-free.
18 Dec 2008
TP-Link 10 Gigabit PCI Express Network Adapter (TX401) works well. I paid £90 each for 2 of them and they have been flawless. Been running them 24/7 in my server for 2 years without a problem.​
Man of Honour
20 Sep 2006
Get second hand server NICs from eBay, from a reputable brand such as Broadcom, Intel, Mellanox etc, with the correct height PCI bracket and SFP module/RJ45 option. Most of mine are Intel X520's or Intel 82599.
2 Sep 2013
That motherboard might be a minor bit of an issue.
You only have 1 full PCI 4.0 (Or is it 3.0?, just checked it's confirmed PCIe 3.0) x16 slot that's fully wired according to the specs. Usually reserved for your GPU.
The second PCI 3.0 x16 slot is only a x4 wired slot. AND it shares bandwidth with your m.2 NVME drives as well if they are installed. So this is unlikely able to get the most from a 10gb network card. You can certainly fit one in, but full 10gb bandwidth is unlikely.
Your remaining slots are x1 slots (electrically wired, or physically actually a x1 slot), so wouldn't be able to saturate the 10gb card either.
It might not be worthwhile jumping to 10gb network with this motherboard. Not unless if you want to swap out your GPU to another slot.
For reference, I've got a 10gb card in a PCI 2.0 x4 Slot (Which should be more than 2GByte/second but as it's a shared channel it only nets me aroud 600-700MByte/second). Still OK. But not 10gb (950MByte+/second)
Caporegime
11 Mar 2005
Leafy Cheshire
Which is still a significant upgrade and would easily saturate a SATA SSD, for relatively small cost its worth upgrading.
2 Sep 2013
Oh without a doubt it's a worthy upgrade. I've certainly enjoyed my upgrade of it. :)
The only thing is, we don't know what purpose this network upgrade is for from the OP. And we also don't know how many other devices are plugged in and sharing the bus (on the system with that motherboard). All of which can impact on the throughput of the network. It might be that they want to share the m.2 NVME, in which case they might be scratching their head as to why they're getting such a strange number for network throughput instead of standard 1gbps/2.5gbps/5gbps/10gbps numbers. Which can lead to all sorts of diagnosis procedures that may end up ripping out fully functional stuff and replaced when it's entirely unnecessary as well, so just pointing out that there'll be issues for the OP to recognise if and when they attempt it.
5 Dec 2002
The 80's
I use a Intel X520 in my server. Just be cautious, mine was a Dell part (wasn't mentioned in the listing) and would stop the machine from posting with a certain amount of ram in it. I had to do a mod to the card (Block pins 5 & 6 on the pci-e connector) to allow it to post with all the ram. I also had to modify the firmware (Just a bit flip which can be done in linux with ethtool) to allow the use of any DAC/SFP+ Modules. Was a right pain, but was quite satisfying to get it full working in the end :cry:
If getting a x520, just make sure your getting a Intel variant.
