MATX Spec - is this ok?
21 Jun 2023
Cheshire
Lian Li Lancool 205M Mesh Micro-ATX PC Case Black
Thermaltake Toughpower SFX 850W 80 Plus Gold Native PCIE 5 Power Supply​
Thermaltake "Kettle Plug" Mains Cable
Asus TUF Gaming B650M-Plus WIFI (Socket AM5) DDR5 Micro ATX Motherboard
AMD Ryzen 9 7900 Twelve Core 5.40GHz (Socket AM5) Processor - Retail
Thermal Grizzly Kryonaut High Performance Thermal Paste - 5.5g / 1.5 ml
NZXT Kraken 280 Elite Black RGB AIO CPU Water Cooler - 280mm
Corsair Vengeance RGB EXPO 32GB (2X16GB) DDR5 PC5-48000C30 6000MHz Dual Channel Kit - Black (CMH32GX5M2B6000Z30)
Samsung 980 Pro 2TB M.2 2280 PCI-e 4.0 x4 NVMe Solid State Drive
Palit GeForce RTX 4080 JetStream 16GB GDDR6X PCI-Express Graphics Card​
Lian-Li UNI AL120 Addressable RGB Black 120mm Fan (for Exhaust on the case)
Microsoft Windows 11 Pro 64-Bit DVD - OEM (FQC-10528)
Will all that work fine together? Will it be run cool?
I will be playing mostly 4k games such as Skyrim and Cyberpunk but majorly modded. Mixed in with some WoW, Diablo4 and FPS games.
I need a small but highly powerful computer due to space issues.
Only issue I see is that case only takes 240mm aio while you have specced a 280mm aio.
You don't need an SFX psu a normal atx PSU will fit up to 180mm in length.
According to TPU's review, the 7800X3D uses less power and runs a bit cooler than the 7900 non-X, while offering higher gaming performance. You're also fine with pretty much any memory of C36 5600 or better, whereas the non-X3D is better with what you have chosen.
Corsair Force MP700 2TB NVMe PCIe 5.0 M.2 Solid State Drive, am i going to get any noticeable gaming performance over say a​
Samsung 980 Pro 2TB M.2 2280 PCI-e 4.0 x4 NVMe Solid State Drive?​
any more expansion on that comment?
Games may load a max of 1 second faster then a pcie4 m2 drive but on no affect on FPS. Pcie5 m2 main benefit is moving large files from one fast drive to another where the speed equates to time.
If you use the reply button we get notified so makes life easier and reply faster.
As mickyflinn said, you're looking at a second or two at best.
It's possible that this might change in the future with DirectStorage being better used and faster flash, but right now I wouldn't bother.
