Amazon delivery instructions
Man of Honour
29 Mar 2003
Stoke on Trent
Hi you wonderful humans.
I need to change my special instructions quickly from "Please leave items in the blue bin behind the gate" to "Please leave items in the blue or grey bin behind the gate".
Now I know it says the former because only last week I asked a driver what it said on the special instructions.
After about 10 years I want to change it but I can't find it.
Google takes me to different places eg
Go to the last order you made and click on tracking
Go to account, edit address and click on delivery instructions
Neither of these allows me to put my own instructions in, I just get standard things I can tick on like 'Side of the wheelie bin' or 'Leave at the front door' etc.
Does anybody know exactly where my old instructions are so I can change a couple of words please?
Account>addresses>click add delivery instructions under the box with your address in. It has some pre made options but I check leave with neighbour and just fill it in with whatever instruction you want, not necessarily the neighbours name and number.
Also, when you're at the checkout you can add your own instructions.
It doesn't allow you to put your own instructions in, I said that in the OP
I should have asked Mrs Sexy
Edit Address
Add Delivery Instructions
Add more instructions
Do we need additional instructions to find this address?
just leave it as they will deliver, a huge tv outside your front door.
then complain
I've started using the Amazon lockers, down by the mortuary, at work if I know I'm not going to be in.
I always use amazon lockers when possible
Some supermarkets have them outside in the carpark so you can collect even if the business is closed
I had one amazon driver put a parcel under my car on the drive.
He'd only been at the door for around 10 seconds because as he was getting up I opened the door, so he had to go get it and hand it to me properly.
Had an order delivered last week, delivery person ripped my letterbox off. (one of those where the internal flap doesn't open fully, to stop someone putting an arm through to grab keys). Totally ignored the delivery instructions where I state "don't force the letterbox, knock the door if required".
Will use Amazon lockers in future I think.
Last few instructions I've left (does allow free text) the delivery driver had no access to see it as I got a phone call each time.
I just have delivered to a hub if possible as I can't do with the uncertainty, coop in wadebridge in my case on my commute route
