issues 3070 fe mw2
9 Aug 2013
S. Wales
im having a nightmare trying to figure out what in hell is going on, got to point last might i reinstalled windows, all has been fine but all of a sudden my fps have gone through the floor, sometimes down in the 30 fps range and its only drawing less than half its pwr, temps are fine, but cant figure out what is going on. screen shot took earlier below, pulling less than 100w have tried with and without afterburner, using vrr to see my fps using tv, it was fine yesterday around 100 fps at 1440p using dlss. im just scratching me head:cry:
I’m sure you’ve checked this out, but in case- this happened to me in the past I figured I set a performance sapping undervolt profile on afterburner- when realised I took it off and regained 15-20 fps.
indeed i was undervolting, but made no difference if i disabled it, its still only pulling less than half its pwr, its so werid.
It's a problem with the latest update of the game released earlier this week. Everyone's frames have tanked. Acti are very slow with a fix which is crazy.
ah right explains it. as i just tried a benchmark and my gpu is running perfectly fine. saves me digging any deeper, strange why its only using half its pwr though. when i boot it up instead of full screen i only get a quarter, even though fullscreen exclusive is selected, its a pain chaging it every time, bloody updates
well even after updates its still only showing around gpu usage around 60% and around 100w max, even at 4k:confused: should be gpu bound, cpu usage is low percent. its all too **** tbh even after a full windows reinstall
no undervolt(both at 4k dlss performance
undervolt
the gpu usage is way less than 99%
