- 27 Mar 2013
There's more than enough juice, don't think I go above 50% on the amp volume.That'll hurt speaker efficiency though, by a couple of dB (means you need more power for same output)
Yes, but it's not up to your several k levelDo you have a sub? For movies you need one, as those speakers won't be capable enough.
. It's a bk xxls 400.I got my 55"CS back on Black Friday, with a little rangling playing shops off against each other eventually got it from Richer sounds for £879. Its a cracking TV, its so good I'm watching far more films than I used to. Being a hybrid of C1 panel and C2 electronics, I was a little worried it wouldn't be bright enough, but actually I find it too bright, I've had to dial it down a little, mind, my TV room is north facing with a good size window but no direct sun light.I'm late too, 55" CS owner. very happy with it. OLED is like an automatic car for non petrolheads, once you go to it, you can't go back.
OLED is an absolute game changer for me, and probably for you too!I got my 55"CS back on Black Friday, with a little rangling playing shops off against each other eventually got it from Richer sounds for £879. Its a cracking TV, its so good I'm watching far more films than I used to. Being a hybrid or C1 panel and C2 electronics, I was a little worried it would be bright enough, but actually I find it too bright, I've had to dial it down a little, mind, my TV room has a large north facing window and hecne no direct sun light.
Joined the C2 gang
Not in vivid mode haha. It's in expert bright room and quickly eyeball tweaked,still playing around. Can't really do a surround setup..neighbours.In vivid mode?
Also I'd paint the right wall black to reduce reflections. Change it to one of the cinema modes use recommended settings as starting point. Check for 1:1 pixel mapping overscan/understand etc
And buy 32.8.8 system![]()
The TV sound is...fine. Although I have nothing to compare it to notice the drastic difference
My plasma has been retired upstairs after many many years of faithful service.
Maybe it's the pass thru of the TV. I think there's a setting that let's you choose. I assume you get sound out the TV speakers from the ps5?I've just got my lg oled and I can't get the ps5 sound to come out of the external speakers. I set the TV settings to optical.
TV is connected via optical cable to a mini dac which is connected to Yamaha active speakers.
The TVs YouTube app sound did come out the speakers though, so seems an issue with the ps5?
Just to follow up as weird as this was, it is now all working. I wanted to watch "Earth" on catch up through BBC iPlayer and it played with out any errors. The TV did receive another FW update since my last post so perhaps that has inadvertantly fixed/reset something. Happy days though.My5 plays the first ad then just stops. Doesn't load the following ads (1 of 2 for example). But yep player and itvx don't so anything. So strange.
