Pico 4 Accessories thread
New Pico 4 owner here, first venture into VR and am pleased with the headset, at the moment I'm just using it stand alone downstairs where the router is, but will want to try PCVR at some point soon. My PC is upstairs away from the router and the 5G signal is not good enough so I have bought a 5m USB cable that has a power injector. I've read threads that the USB connection can be a bit ropey and it's better to get adapters to allow the USB lead to connect directly into an ethernet port. Can anyone advise if the USB connection is good enough or if anyone's tried connecting to the wired network using adapters.
What I would do is get one if those network things you plug into mains, so router connects to the mains , another one near your headset, that one will be wired or wireless so you'll be able to connect via WiFi still at 5Ghz
Something like this
Thanks for the heads-up it definitely looks like it could work, just to boost the 5G signal so it's available upstairs. Still interested to hear from anyone that uses the Pico cabled, either USB or into a router / switch or is it better to stick with wireless?
Sorry, but, you shouldn't buy what Shi has recommended. The problem is that it will increase latency too much.
Is the router connected by Wifi or network cable to your PC?
The router is downstairs, I have a CAT6 cable from the downstairs router coming upstairs connected to a gigabit switch which my PC and printer are connected to. Having gone down a bit of a rabbit hole following Shi's post I think what I need is a dual band access point that I can plug in to the upstairs switch if I want to stick with wifi !?!
If the PC is wired into the router, all you really need is a cheap second router. Plug that into the network, sit it on top of your PC, and use it as a bridge to your PC. PC is still wired, but you can use the 2nd router to make a new wifi just for your headset, in the same room as your PC.
Basically, you need a wifi signal in the same place as you want to play, and cables to your pc/the device supplying that wifi.
All you have to do is buy another router, either AC or AX, and put it in the room beside your PC. Connect your PC to a lan port on the new router, connect the switch to a lan port on the new router and set the new router in Access point mode. It's pretty easy to do. Asus RT AX-55 is a good one to get.
I was looking at the TP-Link AC1750 / RE450 Wi-Fi Range Extender, apparently you can change it from a range extender to an access point in the TP-Link app.
i couldn't find exactly what i was looking for on OcUK
but now I've come home i can do a little more searching
this is what i meant
something like that, but yeah don't buy the one i linked tom that was just an example, like this one is just an "example"
He doesn't need it, his PC is already wired into the router. Powerline devices also generally aren't amazing, they can work well, but it depends a lot on the electrics, and if it's on the same loop etc.
There is an AC 1750 access point and an AC1750 Range Extender. Confusing I know!! Yes, you can change the RE450 to Access point mode. I guess you could run another network cable from your Switch into the room where the PC is and use that cable for the RE450 setup in access point mode.
I have a 5 port switch in the room with the PC so good to go :cool: The RE450 is a cheaper and tidier option than another router so is probably the way I'll go but as I already have the USB lead I'll see how I get on with it. I don't have a lot of room to move about in the PC room so PCVR will most likely be limited to seated games so a cable shouldn't be too much of an issue as long as it works as well as wireless.
If you aren't doing much moving about and mainly sitting down, the USB cable will probably be fine. I know there were issues on release with wireless through Virtual desktop been much better than the cable. Haven't seen many complaints lately, so I am presuming that PCVR through the cable is much improved now.
Am liking the face cushion, it looks like it eliminates any chance of light leakage allows your eyes to get closer to the lenses, as it comes in a seperate box hopefully you can buy it on it's own.
I'm very tempted to buy
cant buy them separately unfortunately
id like to get this and the PU leather if I'm honest
I've got one of the AMVR headstraps on the way. Should get it tomorrow according to the tracking info.
Will post some impressions once I've had a chance to try it out. I also have AMVR's original facial interface with PU pad, so might try that with the halo strap to see how it compares with the new silicone gasket. I do like the look of the concertina design from a comfort p.o.v. but do wonder if it'll be more prone to fogging up the lenses.
Received the AMVR halo strap a few days back and have spent a bit of time with it now.
Was originally planning on writing up some detailed impressions but quite honestly I think this guy covers things well and his impressions align quite closely with my own.
Just to add a few of my own observations on top.
The gasket doesn't seem to fog up very much at all. I did initially wonder if it might be something that AMVR would eventually sell separately, but imho it really needs to be used in conjunction with the halo strap to be usable. Due to the lack of any rigidity (it's just soft silicone) it feels very loose and unstable on the head when used with the standard strap. When the strap is tightened the gasket compresses and results in the lenses contacting my eyeballs long before I can achieve a secure fit.
Light bleed is an issue as the reviewer mentioned. It is limited to the sides and can be mostly be mitigated. But it's a faff and becomes tiresome quite quickly.
I've not tried a halo strap before but personally I feel like the pad on this is too small, sits lower than I would like (presses quite firmly against my forehead) and doesn't really offer much adjustment. Yes, it can be slid backwards or forwards which helps but the angle the pad is mounted to the halo is fixed.
The one aspect thing I do very much like is the rear pad. It's great! Much softer than the stock one and being recessed it removes any nasty hotspots. If there was one accessory that I think AMVR should offer separately, it is this.
After much experimenting I've decided to ditch the halo and gasket. I'm absolutely keeping the rear pad but am now pairing it with the more traditional AMVR facial interface I was previously using. Whilst less glasses friendly (not an issue for me) I find this combo provides a more comfortable and secure secure fit, entirely eliminates any light bleed and find I can hit the sweet spot much easier. Does get a little warmer but you can't win them all!
Don't get me wrong, the halo strap isn't bad. It's actually pretty good but I just feel it could have been even better. Maybe it just wasn't a good match for my head / face shape and others will look on more favourably.
@jello Thanks for taking the time to write up your thoughts. It's a shame that the facial interface suffers from light leakage as otherwise it seems to offer some real benefits over the original. I can definitely see the rear head pad being more supportive and with the vents a lot less sweaty in use and is something I'd be interested in buying if they sold it separately.
