Decided on a replacement?@Demon I might be selling my individual F80 Comp if you wanted a look at it? I'm not far from you.
Potentially, I'm doing some man maths and having a good think. I would struggle to find another individual F80 with the same spec as mine, however it's not really practical if I want to put the dog in it as an example and I really miss a manual gearbox. I also want something slower and more chuckable.Decided on a replacement?![]()
think I'd want to see if two screen have different amounts of glare&reflection under sunlight - I assume new screen is not a different tech - Amoled - otherwise there'd be more publicity;Or is LCI that much better?
Thanks for the offer.. I’m flitting between 4 seater convertibles, something like the m340i touring (for its practicality and looks) and an Aston Martin Vantage roadster, so at the moment the f80 wouldn’t fit the bill.. awesome car though!@Demon I might be selling my individual F80 Comp if you wanted a look at it? I'm not far from you.
Both or instead of? They’re very different cars….Thanks for the offer.. I’m flitting between 4 seater convertibles, something like the m340i touring (for its practicality and looks) and an Aston Martin Vantage roadster, so at the moment the f80 wouldn’t fit the bill.. awesome car though!
How about a Range Rover? Or Caterham?Thanks for the offer.. I’m flitting between 4 seater convertibles, something like the m340i touring (for its practicality and looks) and an Aston Martin Vantage roadster, so at the moment the f80 wouldn’t fit the bill.. awesome car though!
He should probably consider a long wheelbase Mercedes Sprinter van as well.
If you don't need the room, why not go for an M3 saloon? They are significantly cheaper than the touring tooOh it's quite easy to have a whole skew of options isn't it? I'm going between a Cayman and an M3 Touring for example. I don't need the room, but love both of those cars.
Looks like exactly the same spec as mine!A bit crazy and left field.. but all this talk of M340i's had me looking on the Used Approved website and found this late this afternoon:
BMW 3 Series M340i xDrive Touring 3.0 5dr
Introducing the BMW M340i xDrive Touring, where performance meets versatility in the most captivating way. This ultimate driving machine combines exhilarating power with ample space, making it the perfect companion for both thrilling drives and practical everyday use. With its stunning Dravit...usedcars.bmw.co.uk
Seems high spec, (Comfort pack, visibility pack and technology pack). Decoding the VIN to get the decoded build list:
S610 Head-Up Display
S654 DAB Tuner
S688 Harman/Kardon Surround Sound System
S6AE Teleservices
S6AF Statutory Emergency Call
S6AK Connected Drive Services
S6C4 Connected Package Professional
S6NW Telephony With Wireless Charging
S6U3 BMW Live Operating Area Professional
S6U8 BMW Gesture Control
S6WD WLAN Hotspot
Driver Assistance And Lightning
S534 Automatic Air Conditioning
S544 Cruise Control With Brake Function
S5AC High-Beam Assistant
S5AQ Active Guard Plus
S5AZ BMW Laserlicht
S5DA Passenger Airbag Deactivation
S5DC Rear-Seat Headrests, Folding
S5DM Parking Assistance System
Wheels And Drive
S230 Extra Package, EU-Speciifc
S248 Steering Wheel Heater
S258 Tyres With Runflat Properties
S2NH M Sport Brake
S2PA Locking Wheel Bolt
S2T4 M Sport Differential
S2TB Sport Automatic Gearbox
S2VB Tyre Pressure Display
S2VF Adaptive M Chassis
S2VL Variable Sport Steering
Environment And Safety
S302 Alarm System
S322 Comfort Access
S3KA Acoustic Comfort Glazing
S3MC Indiv.Roofrailing,Mirror-Fin.Shadow Line
S812 National Version England / Ireland
S850 Dummy-SALAPA
S853 Language Version, English
S880 On-Board Literature, English
S8KA Oil Service Interval 24 Mths / 30,000 Km
S8R9 Refrigerant R1234yf
S8S2 Coding, Alarm Signal
S8S3 Automatic Locking During Starting
S8SM Car Ident. Number Visible From Outside
S8TF Active Pedestrian Protection
S8TG Thiefproofing Device
Individual Equipment
S760 High Gloss Shadow Line
S775 Headlining Anthracite
Other Equipment
S1CB CO2 Equipment
S1DE Exhaust Emission Standards EU6 RDE
S1PW 19" Light-All.Wheel Dbl.Spk.792M Em.Op.
SA090 90 Ah AGM Battery
I prefer higher spec/slightly older, a Jan 2020 registered with 21K miles for £40.5k in Dravit seems OK? Or is LCI that much better?
1. Must be an auto (that's easy to fulfill) - The V8V isn't a proper auto, but an old single plate clutch, so worth bearing this in mind and whether or not you'd be happy with this.Crazy isn't it.. I have a list of requirements that can't be met*, so I have to choose which is the best compromise..
2. Must carry 4 adults + dog (easy in some cars)
3. Ideally a convertible since I've had 5 now, and also had many sports bikes so like that open top motoring
4. With getting older, easy ingress/egress would be nice
5. Has some aspect that makes me like it, so a little unique, or fast, or quirky, or something.
6. I love tech, so love gadgets on the car..
Auto - Yes
4 Adults and Dog - Probably, though dog obviously not in the boot
Convertible - Yes
Easy Old Man Access - Yes
Quirky/Unique - Absolutely
Tech - Yes
Auto Trader UK - New and Used Cars For Sale
Find your next car with Auto Trader UK, the official #1 site to buy and sell new and used cars. Over 400,000 cars online. Simple, easy, quick!www.autotrader.co.uk
You know you want it.
Almost banworthyAuto - Yes
Convertible - Yes
Tech - Yes
