Not sure that I get what you mean?
NVidia have, until recently, not been very friendly to the open source community.
If you want hardware accelerated video playback on Linux (especially in browser) you're going to need AMD. Even the open source amdgpu driver runs VAAPI perfectly, but HWA video has been broken since forever on Nvidia no matter which driver you use (open/proprietary).I use Linux on a Laptop that has nVidia graphics and its absolutely fine.
Rainmaker:
if you only care about rendering the desktop and playing back x264 flawlessly, then any cheap 2nd hand AMD card will suffice (even down to RX280 or earlier). If you want x265 or VP9, you're going to need anything after Vega and you'll pay a lot more. For games? Dunno, I don't play them.
Right, but I'm not talking about drivers or their quality. Nvidia don't support VAAPI / hardware accelerated video playback on Linux, period. There used to be a VDPAU-VAAPI adapter but it broke a long time ago. As such, Nvidia will always be inferior to AMD, especially on anything with a weak or old CPU, and/or with a battery.I am aware that AMD work out of the box and its great as I said.
The nVidia drivers that I install to it, are also great. Yes, I have had an issue or two here and there for some strange reason that I have never bothered to care about, but its not that often.
Regards Wayland , Still AMD best bet for now. Having said that not tried a 30xx series.
Hardware encoder(AMF) works well on the 6000 series just to note.As others have said, AMD cards work very well. I've been running a RX 580 for some time and am looking at a RX 6650 XT soon.
One point worth mentioning though is that hardware accelerated encoding is crap AMD cards. Even though newer RDNA3 supported models suck compared to NVENC, and don't even bother with the older models, so if you plan to do any encoding, make sure you have enough CPU resource to handle it, or some other hardware to offload to such as Quick Sync, or an additional suitable GPU.
Yeah, it's much improved, but NVENC still whoops it. Personally, I prefer to go with a beefy CPU with plenty of cores and cache if graphics intensive work or games are required simultaneously with encoding.Hardware encoder(AMF) works well on the 6000 series just to note.
In what way ?Yeah, it's much improved, but NVENC still whoops it. Personally, I prefer to go with a beefy CPU with plenty of cores and cache if graphics intensive work or games are required simultaneously with encoding.
Yeah exactly, the picture quality is better on NVENC, but it has come a long way, and HW encoding is totally usable nowadays both on 6000 and 7000 series cards. If you went the best of the best quality though CPU is the one.In what way ?
It encodes on the fly via GPU at whatever bitrate you wish so not sure what am missing ! Quality wise issue ?
I'd post a vid but @humbug and @Curlyriff swear a lot ! oh and me too![]()
