New 4070 Flickers..
Si.
Si.
22 Oct 2002
Melbourne, Aus
Hi all,
Just replaced my 6700XT with a new 4070 card and the performance is great, but I'm getting intermittent flickering, not just when playing games, but open the desktop also. Never had any issues like this with the AMD card. Sometime it's just a few ms, the times the whole screen will go blank for 1-2 seconds. Boots don't find it, and I have lately NVIDIA gamer drivers installed.
Anyone got any ideas how to fix this?
Do you have a freesync monitor and enabled g-sync? If so they probably are not compatible unfortunately
I don't think my monitor is freesync
Sounds like your cable. Try lowering the refresh rate.
Monitor is only 60hz, and using the same cable as before.
It also seems to glitch when using RDP to the PC. RDP drops with a display error then I need to re-connect, so I don't think it's the monitor or cable.
Could it be a faulty card? PSU issue? the 4070 is low power draw so I didn't think it would be a PSU uses (the 6700XT was working find for 2 years). I'm going to try swapping PCIE power cables just in case there is a PSU issue.
Other things to try:
Remove and refit the new GPU.
Check if you have the latest bios for the motherboard especially if there's a newer one to support or improve stability with NV 4000 GPU's
Reset the motherboard bios to default but note down any settings you may have in place such as overclocks, voltages etc so you can reapply later. I couldn't get a new GPU to work recently until I did this but I would expect it to be this way (either work or not), rather than cause something like flicker. Could be worth a try anyway.
Could also try refitting the old GPU and run it for a while which would rule out any problems with the cables.
What is your monitor?
Did you remove all traces of the AMD drivers? There could be a conflict going on so if not use something like DDU to uninstall the AMD drivers, it may actually be a good idea to remove all GPU drivers and reinstall the latest Nvidia ones from scratch.
If that does not work, try a older driver.
Also.
If it is not Freesync or G-sync capable, dissable it in NV control panel and see if it improves.
Flickering seems to be a widespread issue with the 4000 series. It seems to be a driver issue. I am pretty sure it shouldn't be as bad as you are experiencing, or far more people would be complaining about it, perhaps it is some other driver that you have that's causing the issue.
If your monitor has any freesync or gsync options turn it off using the monitors internal menu.
There's been a flickering issue in the last couple of Nvidia game ready drivers (since the one around the time of the Diablo 4 launch). This could be the problem. Disabling g-sync made it go away for me, and could be a workaround until they finally get around to fixing this.
I found the reason. The issue is in bad or dirty connectors. In most cases, the problem is not related to the cable itself, but to the pins of the connectors at the end of the cable. Maybe some of them have oxidized pins or do not fit perfectly, or are dusty. Even a cheap cable for $5-7 works with the GeForce RTX 4070 super video card at resolution 4096 x 2160, a 120Hz refresh rate, G-sync enabled for both windowed and full-screen modes, a 32-bit color depth, RGB format, and full dynamic range. The monitor is LG Electronics TV SSR2. Before I only had stable work with 1920x1080 resolution, using an expensive cable. I reconnected the cable a few times and found that it sometimes gives problems, and sometimes not. Then I have made tests with a cheap cable 1.8 meters long, and it also works at maximum resolution and 120Hz refresh rate. Perfect.
