Upgrading from a 4770k system
22 Oct 2010
So i've had a home built system for about 10 years now centred on the 4770k and I feel it's time for an upgrade
It's water-cooled in a corsair 750D case. Reservoir & pump combo is a front bay mounted XSPC unit D2 XSPC X20 750 with 1x 140mm, 1x 280mm & 1x 420mm radiators.
I have a Dell S2719DGF monitor - 27" 1440p 144 Hz that I'll be using and don't need a keyboard mouse or Windows and I was thinking of keep the watercooling & the case too.
I'd like a recommendation of a MB, CPU + Waterbock, RAM & Storage (I have plenty old drives, both HDD & SSD, but I am sure a new unit would be better than reusing on old drive for the OS)
Also recommendations for a 'starter' air cooled GPU to keep me going till I upgrade the GPU to one with a waterblock in a few months time.
I've been away from the PC building scene for years and have no clue on what's what..
I play mostly Assetto Corsa with a bit of Battlefield & other FPS now and again.
Total budget for now is 100-1200 for the above,
Thanks in advance,
15 Dec 2010
UK
30 Dec 2021
Yorkshire
The 7700 is about comparible and on a newer socket. He's changing the GPU later, this is probably the best for the current budget.
just with him saying the budget was 1200 all in.
the 5800x3d is £100 cheaper, a good B550 is £60 cheaper and Ram is cheper he could put £250 more into the GPU and thats a 6800xt
upgrading from a 4770k he not the type of guy that upgrades ever 12 months so the socket i dont think would matter
15 Dec 2010
UK
Fair points. I put less priority on the GPU as he said he was going to replace it. Your suggestion makes good sense for a full build now.
OP
22 Oct 2010
For a little more context on me upgrading, I started with the 4770k on air with a R9 290X. I eventually did a ghetto-watercooling setup on the GPU using a CPU AIO with a custom bracket and a set of heatsinks.
After that I did 3x R9 290's under a full water loop then eventually replaced them with 2x 1080 Ti's again under water.
They too eventually got sold and replaced with a 5700xt, again under water.
All the GPU's were sold for pretty much purchase price due to the various mining runs there have been over the last 10+ years.
I guess the point is that I'd rather go max on the CPU now as it will likely stay put for a while..
10 Sep 2022
essex
Go for the 7800x3d CPU then and keep the GPU for a bit longer.
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
Its an XSPC Raystorm water block
If you went for Intel your block will fit the LGA1700 socket but you will need a new backplate. See here for details. For AMD you will need a complete mounting kit if they are even available as they did Intel OR AMD versions of their blocks. If going for a new block I wouldn't go with one of EK's overpriced offerings as they are simply not worth the money. Most of the top blocks are within a degree or two of each other and that isn't going to change until someone comes up with a new radical redesign of water block.
12 Apr 2020
I think assetto Corsa loves the cache from an x3d cpu so would go 7800x3d as your starting point and work out from there
Out and about at mo but saw the 7800x3d v 13900k gaming comparison that hardwareunboxed released this morning and the x3d chip beat it 5%,4% and 1% in game average for 1080,1440 and 4k while averaging over 100w less power draw for total system use. I think it was the racing game that was an outlier also that trounced the intel cpu in all resolutions too, though need to check, and on a poxy old 2nd mob at mo that can barely type on
12 Apr 2020
Just looked again and racing game you like, at 1440p the 7800x3d was 28% faster than the 13900k, using 6000ram (didn’t check precise ram timings)think it was compared to 13900k using 7200 speed ram
OP
22 Oct 2010
Thanks for this, I wasn't aware of that YouTube channel and yes that Ryzen looks the better choice,
