Just what is NVIDIA up to?
Ask OcuK if they'd let this go for £500.
It's in B Grade and brand new OcuK selling them for £699 so it's possible they'll let it go at £500-£600 or thereabouts.
Think the guys name is Rob that you have to email.
You've been using Nvidia for far too long. :D
How does warranty work ? Warranty for this item is 90 days as with all B Grade items.
You don't get anything with sapphire either ?
I've seen a 3080 go on MM for £360 the other day, if I needed an upgrade I'd have been all over that.
The 7900XT is not $500.
There is nothing from Nvidia, so they are not an option. AMD do have options.
I was going by my own situation if I had them cards , I have 3080 so have crap options
7800xt similar performance 6800xt for £550 ?
7900XTX is 85% the performance of the 4090 at 56% of the price.
7900XT is 85% the performance of the 4080 at 68% of the price.
79% of the 4090 for the XTX
The 85% Of 4080 number for the XT is correct, it might actually be slightly higher now as a recent re-review by HUB showed the 7900xt has gained 2fps on average from latest drivers (about 1% performance gain from launch). Same possibly applies to XTX as well so it's moved from 79% to 80% of the 4090
I see you guys are just posting the same things over and over again ad nauseum, is there some set of templates you are using and could you dm to me please as i'd like to join in or are we just making up the info as no ones reading it anyway. :p
Circular slide war arguments over 5 percentage points, I've always used TPU and instead of your opponents just saying "oh ok so that's one data point among many" they just flat out say you're wrong here's my slide.
Its impossible to have a rational debate with these people and that's the whole point, they don't want to be rational about it, they take their inspiration from Youtube thumbnails, that's how dumbed down PCMR is these days.
I don’t trust them anymore as they are shilling Nvidia more than AMD
they seem very critcal of nvidia from watching reviews of the 40 series cards without even watching them look at the thumbnails , Its my opinion and will leave it at that , they even exposed them for trying to get them to influence reviews so get brownie points for that
