- 15 Oct 2003
- Chengdu
Where did you get the install media? Just re-download it using the Media Creation Tool, and re-install from scratch.
Dells have a built in OS recovery tool now that downloads the latest image from the cloud.
Why, would a slow connection not be able to complete the download?Assuming you have a fast enough connection to download it in the first place.
Why, would a slow connection not be able to complete the download?![]()
I wonder if anyone has any ideas of how to solve an issue with my Cumulus weather software?
After a tremendous amount of time and experiments.
I tried several variations of operating systems, and discovered that there is a bug with Windows 11 Home/Pro.
I did a fresh installation of Windows 10 Pro, and now everything is working perfectly with no errors.
These are the errors which I am getting on Windows 11 but not on Windows 10 Pro:
PHP[64]: Error uploading to realtimegauges.txt
PHP[64]: Error uploading to realtime.txt
PHP[64]: Error uploading to realtimegauges.txt - Exception Type: System.Net.Http.HttpRequestException
Message: An error occurred while sending the request.
Inner Exception...
Exception Type: System.Net.WebException
Message: The request was aborted: Could not create SSL/TLS secure channel.
Does anyone know what is different in Windows 10 compared to 11 on the SSL/TLS secure channel? Or what is causing these errors?
Any ideas or information would be gratefully received.
Kind regards
Mike
Hello GaryTheSnail, thank you for your reply to my message.Have you contacted the app developers support?
The Software is Cumulus MX and here is the forum Cumulus Forum and the Cumulus Wiki Cumulus WikiCan you link me to the app you are using?
This is the reason I have asked whether anyone has any idea, as to why the errors appear only on Windows 11.
Yes, it is connected to a Weather station and my website is My Website.Do you have a screenshot of when the error occurs?
I have it running on windows 11 but not sure what to test when your error occurs to replicate it.
it's running because I can access the web server on http://localhost:8998/ unless it's when on your side it's doing something with the data set.
I'm trying to get my head around what this software does.
EDIT: oh it looks like it's for connection to weather station, is that right?
Perhaps weather software discussion can have its own thread?
