I’d only suggest doing that if completely confident the paste is still fluid/tacky/whatever the correct term is.Have you tried a flat bladed screwdriver under the corner where there’s space and just gently twist/prise it off?
hairdryer, lowest setting.......let it slowly warm the old paste up. then gentle twisting action at the corners.....and patience. much patience
Just because I've moved on, doesn't mean there isn't plenty of life left in it that someone might be able to make use of...if it's an upgrade isn't it all going in the bin anyway?
Glad it worked. In hindsight, my advice of a hammer and chisel would not be idealAwesome advice, worked like a dream and didn't take too long, either
Just needs a bit of a clean up and then can be added to my collection of archaic CPUs to sell (alongside an i3 2100 and an i5 2500k)
Glad it worked. In hindsight, my advice of a hammer and chisel would not be ideal![]()
Glad you didn't try to pick it off with a screwdriver, that's very poor advice.
What you should have done is, played a game for a few mins or a benchmark and then it will hear up the paste and you can then just take it off normally.
Looks like to much paste as well, or is that the stock cooler and that how it came?
Prying the CPU off the heatsink with a flat-blade is the recommended method for most high-end server CPUs these days when the CPU + heatsink are inserted as one item. I believe it started with LGA3647. Do need to be careful to get it deep enough so as to not bend the corner of course.
While too late for OP, the advice I seen which I took when I've upgraded a CPU or a cooler is to run the system for a few minutes first to get some heat into the thermal paste which can make it easier to twist the cooler off.
For AM4 CPUs I'll always disconnect the CPU fan and just turn it on a while. If I don't do that, it's almost a guarantee it'll be pulled out with the cooler.![]()
So damn lucky you didn't bend any pins!
Thread or thin wire is a good call ive had to cut things apart with this method before, i cant remember what is was but im sure i recall instant gasket and a guitar string.Heating up first is definately the best option if its available. Ideally run the PC for about 5 minutes being removing the CPU Another method if your unable to heat the CPU is to use dental floss or thread to cut though the tim. As for the screw driving method, I'd be more worrid about damaging the IHS as you'd have to be pretty ham fisted to launch the CPU across the room!
Have just upgraded my CPU after nearly 5 years of solid service.
Only problem is that when I pulled the HSF, the processor came with it!
Any advice on how to unstick the processor so I can repurpose it?
