- 18 Oct 2002
Looking to get back into MTB after a long break, when my last got nicked and I ended up spending the insurance money elsewhere...
I don't really want to spend more than 500ish at mo, as I'll just be going on rides on my lunch break around field/wooded areas and simple trails. Swinley is also near me which I used to go to occasionally.
I was looking at this:
Vitus Nucleus 29 VRS
With a code I can get it for a smidge over £500. Are there any better options around this ballpark?
Cheers!
In typical OCUK fashion, someone asks for a recommendation based on a max budget and I'll suggest something higher.
this is £150 more and comes with a vastly superior fork, better brakes, better tyres and a dropper seatpost. 27 inch wheels but if you're a small, medium or want a more agile bike then it's perfect.
If you get back into riding and end up looking to progress, you'll be glad you paid the extra.
But if you do have a strict budget, then that bike is still a great choice.
