- 8 Nov 2006
- Scotland
Download link and credit for original creators - https://www.overclock.net/threads/n...ies-including-founders-edition-cards.1807438/ (Please read whole OP)
Just dropping this here for OCUK as it's quite a breakthrough for BIOS flashing for many people stuck on FE cards/with voltage limits. Most of us will have a good choice of BIOS to flash for our cards to eek out some more power, others are far more restricted depending on the model of card purchased.
As I just posted in the 4080 topic here, I went straight to testing the 1000w 4080 BIOS I previously couldn't flash due to a board ID mismatch as the 4080 has a few SKU's. Not only did it flash fine, the results are a bit terrifying lol
673w of power draw on a 4080 at 1.125v lol (this BIOS goes up to 1.195v
Obviously I don't recommend going right to a LAB BIOS with power limits like 1000w (especially not on air cooling ~ Or even water to be fair, look at my hotspot temp with furmark lol!), but if you have a FE card or a 4xxx series that came voltage limited (IIRC some cards topped out around 1.07v whereas 1.1v~1.11v has been quite common in others) this could be a chance to eek out some more power.
Preliminary tests show as long as you don't do something stupid then flashing a BIOS made for your model of card (4080 -> 4080) is going to work fine, but ymmv and those without a dual BIOS card might be best waiting for even more data feedback.
)Obviously I don't recommend going right to a LAB BIOS with power limits like 1000w (especially not on air cooling ~ Or even water to be fair, look at my hotspot temp with furmark lol!), but if you have a FE card or a 4xxx series that came voltage limited (IIRC some cards topped out around 1.07v whereas 1.1v~1.11v has been quite common in others) this could be a chance to eek out some more power.
