Intel announces 8 core, 528 thread CPU
6 Feb 2019
66 threads per core, this CPU is not x86, it's using RISCV and has a 70w power draw. 3.5ghz clock speed
It's also a big CPU, over 300mm2 but the power draw is very low
The CPU will be built by TSMC on its 7nm process
These CPUs can also be used in parallel, Intel allows for up to 8 of them to be connected for up to 120 cores and and 8448 threads
Obviously not a mainstream consumer CPU; it's a niche targeted design and it's best suited to AI and Data analysis
I don’t read WTF tech FUD, but did you mean 8 cores at 66 threads each? With a decent amount of cache could be interesting at 70watts.
no windows is the CAP
Yes I get windowless is poo. And the cpu is not 64bit.
I’m just wondering dose windows have a cap. You always see people with stupid cpus in gaming systems. Just wondering with CPU’s getting bigger and bigger. Is the a cap in windows that would become a problem soon
Server editions of Windows can usually handle up to 256 cores (that would include any HT or E cores, etc.) internally the Windows kernel can handle 1280 CPU threads. There isn't a specific process thread limit though - applications can spawn 1000s of threads.
EDIT: Updated my post as it was a bit out of date - also supposedly core limits on the different versions aren't enforced since more recent versions of Windows 10 but I can't comment on that.
I've no way of testing it but I believe above a certain point Windows starts to group CPU cores in the task manager.
Not sure there is a real cap on consumer editions, other than a cap on number of sockets (1 for home, 2 for Pro, 4 for Enterprise/Workstations)
MS had a blog entry that said 256 cores but that's debunked if you read the bottom link
Can't find something similar yet for 10/11 but screenshot of Windows 8 with a lot of cores:
In the case of Windows 8 the kernel can support up to 640 CPU threads/logical cores apparently.
You wouldn’t want to use this type of chip but, imaging the potential VM licensing could be interesting.
Bill per core.
