Steam achievements are overrated anyway![]()
Yes yes, but tell that to the chimp part of my brain that enjoys the achievement bloop.Steam achievements are overrated anyway![]()
Especially as you can just give yourself them
Which mod did you use in the end.Thanks for the list, not even played 30 seconds of the game yet and came hunting for a fix to the awful black levels.
I mean, what were they thinking? Looks like I'm playing it on a 10 year old panel. And also, no HDR!?
Does it feel sluggish at all? my laptop is ~45 fps with everything at ultra apart from shadows @ 3840x2400. A little boost would be appreciated.I used the DLSS 3.5 and got it working quite easily in Gamepass version, boosts me from 70fps to 105 @ 4k Ultra
Second one on Dirk's list (OP), the LUT modWhich mod did you use in the end.
This is the one im using with my 5800x3d and 4070...was a massive boost in fps and feels smooth while playingDoes it feel sluggish at all? my laptop is ~45 fps with everything at ultra apart from shadows @ 3840x2400. A little boost would be appreciated.
Starfield Frame Generation - Replacing FSR2 with DLSS-G
Replaces the built-in version of FSR2 with DLSS3 + DLSS-G to enable Frame Generation.www.nexusmods.com
I'm looking at all these tools and directions and going 'Huh'?
Is there an easy way to, say, click download and the program or installer does it all for me? Particularly the StarUI one.
That does sound useful, early game I need as much credits and digipicks I can get. Do you have a link?A really handy mod I found is the one where it changes the credsticks and Lockpicks textures to bright yellow. Makes it much easier to just spot them sitting around when looting an area.
As you guys can see, average FPS increases by about 6-8% and there are some gains in percentile FPS figures as well. The margins might not seem like much but when combined with a GPU overclock for example, you can achieve a double digit perf gain, and in an unoptimized game like this one, you want every frame that you can get...
This mod fixes annoying twitching/stuttering when sprinting on uneven ground.
