OK thanks. I tried this earlier but the button inside is like a slit rather than a recessed button if you know what I mean? I gave up because I couldn't do it easily, and I thought it was a shot to nothing anyway as I've changed no settings.
Any hints? I've just tried sticking a sim ejector tool in there again and no joy, it's really odd.
mikrotik.com
mikrotik.com
mikrotik.com
If I want to connect these together do I really need to buy a £30 Cable?
RB5009UG+S+IN | MikroTik
The ultimate heavy-duty home lab router with USB 3.0, 1G and 2.5G Ethernet and a 10G SFP+ cage. You can mount four of these new routers in a single 1U rackmount space! Unprecedented processing power in such a small form factor.mikrotik.com
CRS310-8G+2S+IN | MikroTik
Take advantage of the blazing fast 2.5/10 Gigabit combo and upgrade your workspace! This switch can utilize the full potential of RouterOS v7: run VLANs, Jumbo frames, link aggregation, ACL rules, and so much more!mikrotik.com
I only need 500mm IE both Items will be together.
XS+DA0001 | MikroTik
Direct attach cable that supports not only SFP 1G and SFP+ 10G, but also the 25G SFP28 standard!mikrotik.com
Seems a great little device depending on your needs, It's only 2.4g though!General consensus on this kit?
The L009 ticks all the boxes for me on paper, decent price, 8 ports, solid hardware.....software apparently decent. My current router is pretty ancient now and I'm pretty sure is limiting the use of my gigabit line.
or om3 cables with transiever sfp+Thanks I'll take a look, never used a DAC cable hence the question
You think £30 for a 10Gbps cable is expensive?! That’s a fantastic price.If I want to connect these together do I really need to buy a £30 Cable?
Do I need it was the queston. I'm sure it is a good price!You think £30 for a 10Gbps cable is expensive?! That’s a fantastic price.
Just get it!Do I need it was the queston. I'm sure it is a good price!
Maybe I could use it at a later date for my upgrade to 25 or 100GB internet but I fear I'll be dead before I see or need those speeds, however 2.5GB for faster AP's in the near future makes more sense just to get what is needed.
