YEAH ******! I wont even hide it! I dont handle heat very well at all. Very much a winter person! I'm not handling this heatwave well at all...Wow, what a drama Queen!
You’re in Scotland, can’t be that hotYEAH ******! I wont even hide it! I dont handle heat very well at all. Very much a winter person! I'm not handling this heatwave well at all...![]()
I wish I was in Scotland... I'm in Dorset! Its only just dropped to 20C hereYou’re in Scotland, can’t be that hot
It’s 29 degrees in my room and I’m as comfortable as it getsI wish I was in Scotland... I'm in Dorset! Its only just dropped to 20C here
I'm dreading going to bed. Its almost bordering on "warm but comfortable" now, with the fan blowing directly on me, I wont sleep with it on though.It’s 29 degrees in my room and I’m as comfortable as it gets
Bring on the winter, hate when it's hot.
I'm the type that still wears shorts in the winter![]()
tesa Insect Stop Hook & Loop STANDARD for Windows Best 5 quid you will ever spend26C indoors here and i've unfortunately just had to close all the windows due to the amount of insects that had found their way inside, would rather be hot with no creepy crawlies.
I saw a couple of flashes earlier, must have been pretty distant as I didn't hear anything.It's cooled down nicely. Helps I'm not stuck in the factory as I'm on the fork truck. Had some lightening earlier but no sign of any rain.
