- 12 Feb 2014
- Somewhere Only We Know
Is it just me or has anyone else experienced and issues with these fittings ?
In total I've brought 4, and they're really not cheap, so far out of the 4, I've only had 1 that haven't failed in some way......yet !!!, whilst connecting the first one the Alan key joint snapped off and fell inside the fitting, leaving shards of metal to fall into my water block, I couldn't get the fitting back out and had to dremmel it in half to be able to remove it from my water block, I then had to strip my water block down to remove all the shards of metal that fell through which turned out to be the 4 little posts that connect the top Alan key to the bottom thread, I wasn't even doing it up that tight, just pinching it up.
The next 2 just leaked like a tap from the same place (the Alan key joint)
I'm using 1 now but closely monitoring it for leaks as I'm starting to rapidly lose trust in these fittings.
imgur.com
Dodgy EK fittings
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
