Hopefully we get the game we was hoping for on release
Yeah I'm glad I waited!
DLSS dll is at version 3.5 now (DLSS 2), DLSS 3.5 is something different, that is Ray Reconstruction which uses AI to remove the RT noise as well as remove the light response latency seen in all light reflections from ray tracing currently. this part of the tech is supported on all RTX cards and can improve fps by a few fps at most because of its nature in improving ray tracing efficiency.I missed all the dlss 3.5 is it just a de-noise for ray tracing? Presumably just for 4 series right?
Phantom Liberty takes place during the main game, not after it (though you can access it even without having saves available - same as you could in Witcher 3). And apparently it is possible to gain access to a new possible ending through it.
Then the "original release" would be in 2023.Probably something that should have been in the original release
Witcher 2.I am still waiting for the day we get a game where each playthrough can be quite different due to choices one makes. Dying Light 2 made a big deal about that. But was only like 2 choices and not a big deal in the end
Witcher 2.
And there is a reason why no games do this. Huge amount of extra work for very little benefit, because most people never replay games.
Witcher 2.
And Witcher 1, three different endings that shows in both Witcher 2 and 3 to an extend.
Whops, was also going to post this.
Check out the system requirements posted earlier for the new update of the game. 1660 falls short of recommended requirements!Hello have not tried this game yet, running a gtx 1660 super will that handle it ?
ran that can i run it tool and the recommended says a nice tick.Check out the system requirements posted earlier for the new update of the game. 1660 falls short of recommended requirements!
Cyberpunk 2077 Phantom Liberty Will Be Very CPU Intensive
Phantom Liberty is expected to hit 90% CPU usage on 8-core chips.www.tomshardware.com
