Yeah, probably just needs a screw tightening but it's only audible when next to it.Never had the issue with mine making that noise is it the outer casing like?
There are no heating elements. The heating works by reversing the refrigeration cycle. Pumping heat from out to in rather than in to out. I do use our single wall split for heating but only as an auxiliary. It works very well and anecdotally it is very efficient. The caveat to that is that really its impossible to calculate the COP because its not really possible to measure the heat energy output.To the people who use them for heating, is the AC your main source of heat? Do you also have a gas boiler?
I'll probably need my boiler replacing in the next few years, it still works absolutely fine but is a very old non-condensing Baxi thing with seperate hot water tank, mavity fed etc etc. The most logical path would be to move to a combi and get rid of the tank but I'm also considering installing a split AC system to use for heating and cooling and getting rid of the boiler completely.
Not convinced by a heat pump yet although I understand the technology is similar, I think the difference is just that the split AC systems have heating elements within the mounted units?
Of course you also will have to consider what will be your heat source for hot water.
Yeah there's clever stuff available but what is the price?You don’t, Daikin do a unit that will do a hot water cylinder and 3 indoor units off a single outdoor unit.
Can air-to-air heat pumps provide domestic hot water?
Yes, an air-to-air heat pump (also known as an air conditioner) can bring hot water to your home. With Daikin's Multi+ solution, heating, cooling and hot water are supplied with one system. It connects up to three units and one domestic hot water tank and is compatible with a 90 and 120-litre tank and a wide range of indoor units, offering unrivalled flexibility. Our Multi+ solution includes an intuitive full-text display on the domestic hot water tank for monitoring and adjustment of all settings, including scheduling and water temperature.
Daikin air-to-air heat pumps | Year-round home comfort
Experience unparalleled comfort with Daikin air-to-air heat pumps. Efficient heating, cooling and optional hot water, all in stylish designs to match your home.www.daikin.co.uk
It's awful today, still running on a noisy portable in our living room which is better than nothing. I just can't convince the missus to get a split unit because she doesn't want "a big ugly box on the wall"
And a ducted unit was quoted at about twice the price which isn't affordable for us.
I'm curious how that system works, is it pumping the heat from the air handlers into the hot water? Good stuff if so but it isn't clear from the website. Typically multi splits can only heat or cool, can't do both simultaneously. If that is the case and the DHW is taking heat from outdoor air then its going to be a problem in the summer time..
2 bedrooms overnight, gaming room most waking days, 5 units total. Overall house cooling usage…
Last year: 406kWh
This year so far: 171kWh
Daikin inverters, most efficient available. Rarely use windows tbh.
Does the Daikin unit include ventilation? If not, you'll need to open the windows sometimes!
The vents are open, they do the rest. At most we’ll open them on latch. We have indoor cats, so can’t open them anymore.
Fair enough. How's the air quality? They aren't really for ventilation as such; more for keeping the building ticking over!
Don't indoor cats choose to be inside or not?
Air quality is fine, we also have dehumidifiers for the winter. Our air con units also have multiple filters that help, the air is probably cleaner than that of outside.
We have a ragdoll that shouldn’t be outside. She’d likely flop in the middle of the road and roll around.
