- 27 Mar 2013
Hi guys I currently use my old HAF X case, which is nice now ever I've got a 6900xt which was a very tight fit. I have fans front, side, top and rear. Would there be any benefit to moving to a different case? My gpu does get toasty, but I only run the fans at half speed due to the noise (that age old tradeoff).
Any advice appreciated, I don't actually have much in my case, a 3700x cpu and and dvd drive (which could get binned off).
Do you have the side panel fan blowing into the GPU?
. I was slightly concerned the heatsink has been badly mounted, but not sure how to check it.
. It's noctura stuff which I thought was pretty good. I used the 'buttered toast method' but I'm not sure if I put not enough on. Very frustrating. It was a new card.
so I've come off it for the time being.
