Caporegime
- 18 Oct 2002
Monster cards, enjoy!!!Agree, it was FE or nothing for me. Feels like a very premium product.
Doesn’t help that EVGA are gone, they made some lovely cards.
Monster cards, enjoy!!!![]()
The general advice is to get one from your PSU manufacture, so might be worth contacting them to see if they can help. Otherwise my recommendation is CableMod, they’ve just released a new revision of their 12VHPWR cable which I’m using. It’s only their adapters which have had problems with melting connectors and not the cables, in the event of a problem their support has been fantastic in getting it resolved.First time 4090 FE owner, long time reader.
Who makes the "best" (read safest/not craptacular Amazon branded stuff) 12VHPWR to 12VHPWR cables? The one that was supplied with the Dark Power 13 as a wee bit too short, so I could do with a 3rd party one.
Thanks in advance.
**edit. To get the latest revision you will need to order direct, mine took 2-3 weeks to arrive because of Chinese customs.
lol what an absolute unit
All straight cables are the updated design. All 90 degree cables will be the updated design once they start shipping in mid/end September.![]()
https://www.overclockers.co.uk/cabl...4q6CKP86qAYB8x6iQXIdJIsMAXPpeyPoaAj8qEALw_wcBDoes anyone know if this cable is safe or one off the fire hazard ones ? Thanks .....
Once you go black....What's the white card being dwarfed by the 'big black unit'?
It’s a 3090 vision - very pretty card IMO!
Will give the Aorus 4090 a full run through and post my mini review of it in a week or so.
The Strix 4090 uses a two slot bracket to hold it in place but is 3.5 slots deep, do I need to remove the 3rd and 4th slot covers for it to fit, or will the cooler fit without their removal?
