- 1 Oct 2007
- Hawkes Bay , NZ
Roast Chicken in the oven?
Apart from just opening the windows that is
I like a nice smelling house. I've the usual fabreze/Air-wick sorta thing plug in triple diffusers, battery powered squirting devices on a timer. They work fine. Trouble is the refills are so expensive. Third party refills are a bit cheaper but not as effective in my experience.
I've a potpouri bowl in the lounge and wondering if theres a nice smelling essential oil I could use to sprinkle over it and let it do its stuff.
I do not like burning things in the house from a safety point of view. (accidents can happen) So candles and burning things like incense sticks are out.
I have no pets and no foul odours to cover up. I just like a nice smelling house.
Oh, and simple too. I can't be bothered mixing up concoctions of ingredients.
Any simple, CHEAP, suggestions?
I get that nose blindness will play a part in time so switching scents from time to time is probably a good idea.
The beauty of these, is the oils last ages as you only use tiny ammounts, and theres millions of different ones to choose from:
Essential Oils A-C
Essential Oils (A C) Explore our diverse collection of high-quality essential oils, sourced ethically from sustainable farms around the world. Eachwww.calmer-solutions.com
And you can buy blends too: https://www.calmer-solutions.com/blends-13-c.asp
Some are simple and cheap.
Agreed. I come home from work and I'm greeted by a lovely, pleasant aroma. 3 or 4 fragrance devices on the go at any given time. I quite like the fabreze and airwick stuff (Call me chav. Maybe I don't know any better.Some are "simple"... rarely cheap though![]()
I'm going to try some of the suggestions here. The ultrasonic diffusers and essential oils will be worth a try, I think.
Pricewise, it isn't going to break the bank but if I can lower the "running costs" then all the better.
Have you got the electric one linked above? Reviews seem hit and miss just and I was almost going to order it.
Using essential oils is definitely the most cost effective option. Can change them about easy enough too.
